Clutch Problem
Old Aug 10, 2009 | 11:39 PM
Sideck's Avatar
Clutch Problem
hi... i don´t know if is the clutch... i have Street ACT with Gruppe-S FWY and Gruppe-S Steel Clutch Line....
when i press the pedal to the floor... like 2 inches before touch the floor i can feel and hear some grind...
i check on the engine bay with the car off... and the sound come from the slave cilynder... i think from the clutch housing... i can hear a grind when i press the pedal complete... like "chrrrrrrrrrrr"
what do you think?? Clutch problem, Pedal Adjust, Slave Cylinder, bad bleed clutch line???
Old Aug 11, 2009 | 08:28 AM
lttldggr's Avatar
Definately not the slave cylinder, nothing in it that would grind. I wish i could hear this grind . Is it loud? Does it continue to grind while your foot is to the floor? It could be something with the TOB alignment but I have never had that problem. Does it make the sound when the car is off?
Old Aug 11, 2009 | 11:13 AM
Sideck's Avatar
only sound one time...on last 2 inches after the pedal touch the floor... when the pedal is complete floored the sound finish... the sound is with the car on or off...
if its the TOB... can i fix that without remove the tranny??
Old Aug 11, 2009 | 11:51 AM
lttldggr's Avatar
If it is the alignment on the TOB, It has to be removed (last resort). Have you driven it since the clutch was replaced? Did this noise appear right after the car was put back together?
Old Aug 11, 2009 | 12:01 PM
Sideck's Avatar
this noise appear tonight after a race... everything works fine but i can feel and hear this noise... i think the sound come from inside like a TOB when press the clutch...
the what i need to do?? i dont want a remove the tranny for that
Old Aug 11, 2009 | 07:45 PM
Sideck's Avatar
Originally Posted by jds89
yea you would have to remove the tranny to replace the TOb unfortunately!! could maybe have something to do with the flywheel
why the flywheel??? this grind is with the engine off...
Old Aug 12, 2009 | 03:24 PM
Sideck's Avatar
another idea??
Old Aug 12, 2009 | 04:16 PM
JKD's Avatar
JKD
I am almost 100% positive a clutch pedal adjustment will fix this. Bring the pedal out.
Old Aug 13, 2009 | 03:57 PM
lttldggr's Avatar
I agree, adjust the pedal. It sounds like you are pusing the clutch further in than it needs to be.
