2.3 stroker Rev
Old Aug 18, 2009 | 05:44 AM
4G63 T's Avatar
2.3 stroker Rev
I have AMS (chicago) kit, currently on Stock HEAD with hks 264/272 and intake manifold.
Currently, Rev limit @ 7,300 but i want to push to 8k. rpm
your thoughts?
Old Aug 18, 2009 | 06:08 AM
browningderek's Avatar
i have some cheap beehive valve springs and rev mine to 8500.
Old Aug 18, 2009 | 06:20 AM
evoDON's Avatar
i didnt think it was safe to rev the stroker kit past 7,500. I know the 2.3RR motor says you can but not just the kit
Old Aug 18, 2009 | 06:27 AM
supersal's Avatar
I rev mine just past 8000...
As long as you got some decent ARP L19's holding the bottom end together it shouldnt be a problem...
Old Aug 18, 2009 | 06:34 AM
evoDON's Avatar
Well i have the ams 2.3L with the upgraded oliver rods, and the kit comes with ARP main studs, says the recommended max engine speed is 7800 (endurance), 8200 drag. Should i be fine with the ARP Main studs to exceed that RPM Limit?
Old Aug 18, 2009 | 06:46 AM
JakeTheVIII's Avatar
The L19's don't hold the bottom end together. They hold it against the head really tight. They are headstuds, not rod bolts or main studs.
I wouldnt rev it past 8k, you got a stroker so you wouldnt need to rev out as high. You probably spent a lot of money on those parts, don't bust them up revving too high.
Old Aug 18, 2009 | 07:09 AM
evoDON's Avatar
yea thats what i figured but they were saying its okay too. so i was curious on if it was possible, i dont mind the lower rpm's with the 2.3L
Old Aug 18, 2009 | 12:14 PM
4G63 T's Avatar
My turbo start spooling around 4k at times i would rev up towards limiter
Old Aug 19, 2009 | 06:14 PM
4G63 T's Avatar
tt
Evo__Lee
26
Jul 27, 2017 11:06 AM
danfalcas
Sep 30, 2015 08:25 PM
marcouxa1
Lancer Engine Management / Tuning Forums
Jun 5, 2012 01:07 PM
AndyCT9W
Nov 6, 2011 08:48 PM
1 WICKED EVO
Jan 10, 2008 05:23 AM
