Gota love Sunoco turbo blue!
Old Oct 14, 2003 | 05:31 PM
Evilution VIII's Avatar
Care to share your safc 2 map for 100 octane with us?
(or me?)
what kind of a/f's and exhaust temps were you seeing with that boost and fuel settings?
Old Oct 28, 2003 | 01:48 PM
MaxR's Avatar
Originally posted by webguy330i
Try a couple of tanks of 91, then try a couple tanks of 94. You should notice a slight difference. You won't notice any real difference between 93 and 94 but I am the eternal perfectionist.
I would love to get ahold of some racing gas for a bit... then again I have no boost or a/f or timing management yet.
here in wash most hi octane gas is 92, but recently a toyota guy told me where to find Cenex 94. after a few tanks i noticed more than a slight difference, there's a definite 10+ hp to be had. plus the 94 at cenex is cheaper than the 92 at chevron. they're only in 20 states but its the death, i highly recommend it.
Old Oct 28, 2003 | 02:09 PM
skibum's Avatar
Originally posted by MattGold
...and they're making power with Mitsu Turbos...
I guess the old saying holds true:
"Talent Borrows, Genius Steals..." - DR
Subaru uses turbos???
Is this true?
I did not know that.
Old Oct 28, 2003 | 02:12 PM
NYEVO8's Avatar
yeah they stopped selling 94 in ny but they have a sunoco 93, and so do other gas stations, i use sunoco 93 now. why would you be using a 91 if 93 is availible?
Old Oct 28, 2003 | 02:17 PM
skibum's Avatar
I live in NY and I still buy 94 at Sunoco.
Old Oct 28, 2003 | 02:21 PM
HobieKopek's Avatar
Go south of the border. We've got 94.
Old Oct 28, 2003 | 03:15 PM
webguy330i's Avatar
I can't figure that one out either.
MaxR, I recently found a source for 100 octane so I've bumped up my tank gas bill about $12 for 3gal/fillup.
Old Oct 28, 2003 | 03:17 PM
webguy330i's Avatar
BTW check out this other thread on octane, some reports on mixing:
https://www.evolutionm.net/forums/sh...threadid=28471
Old Oct 28, 2003 | 03:41 PM
ap-evo83's Avatar
From: RAMAR village, pampanga PHILIPPINES, Temecula, CA
so calif has only 91, so i have to go to 76 to mix 91 and 100. and that sucks!
Old Oct 28, 2003 | 04:55 PM
Fourdoor's Avatar
(or me?)
Shareing maps is not a good idea, every one of these cars seems to be differerent.
On the 93 Octane I was running 20 psi peak falling to 18.5 at redline and it was tuned for 11.5:1 A/F ratio. No EGT.
On the 100 Octane I was running 23 psi peak falling to 20 psi at redline and it was tuned for 12.5:1 A/F ratio.
Keith
Old Oct 28, 2003 | 06:50 PM
Fourdoor's Avatar
One thing I noticed recently was that Godspeed did NOT use SAE correction on the torque figures, but did use them on the HP figures. In reality if you bust out the calculator I made 263 lb-ft of torque at 3800 RPM on the tuned pump gas run, and 286 lb-ft of torque at 4000 RPM on the tuned on 100 octane run. Not 247 and 269.9 respectively.
Keith
ouminan
GSC Motorsports - Charleston, SC
Jan 9, 2015 10:48 PM
Blitz
72
Aug 4, 2008 01:17 AM
CrackerJackToy
148
Apr 5, 2008 05:45 PM
Fourdoor
18
Mar 6, 2004 09:00 PM
AMS
44
Dec 10, 2003 11:50 AM
