Knock on start up
Old Aug 21, 2009 | 06:36 AM
rEVOlution517's Avatar
Knock on start up
theres a strange knock coming from seems from the engine compartment when i start my car, theres also a thump that comes along with that knock. the car drives fine and the knock doesnt really come up any other time maybe a motor mount? any ideas??
Old Aug 21, 2009 | 01:54 PM
sparky's Avatar
Does the knock only happen on cold startups, or does it occur on warm startups as well?
Old Aug 21, 2009 | 02:58 PM
EvoVIII808's Avatar
Check your Oil Level May be Low.
Old Aug 22, 2009 | 06:57 AM
it happens hot or cold and oil levels are good i just changed it.
Old Aug 22, 2009 | 03:02 PM
EvoVIII808's Avatar
hmm what does it sound like a ticking or had knocking?? Ticking would be lifters (since no oil pressure before starting) Knocking could be many other things.
Old Aug 23, 2009 | 05:01 AM
nope just one knock when it turns over then nothing
Old Oct 28, 2009 | 04:39 PM
mirebih's Avatar
I dont want to start another thread, and i have the same problem.. Does anyone know.. It is cold outside, and i also heard it knock few times when i shut the car off.
does anyone know what could be the problem??
Old Oct 28, 2009 | 04:42 PM
EmeryatSTM's Avatar
Check your exhaust, It may be hitting something when the motor moves.
-Em
Old Oct 28, 2009 | 09:18 PM
malonejr2000's Avatar
sounds like your down pipe banging around down there...had that same problem..if it sounds like a clunking and then like maybe somebody was tapping on your down pipe with a small hammer its for sure it...if you got the ebay down pipe or o2 housing you can get it
Old Oct 29, 2009 | 12:59 PM
mirebih's Avatar
That sounds about right.. I have BR TBE, and its getting worse now.. It used to be at start up only, not its when i shut it off, and also when im slowing down at red light or stop sign..
It almost sounds like my there is a problem with my wheels or axels, but wheels nor axels dont have anything to do with start up.. I gotta lift it up and check under.. thanks
bumblebee04
Jun 27, 2011 11:44 AM
Crester
Nov 17, 2010 08:09 AM
Daskid
Jul 14, 2009 06:24 AM
Nomad4g63
34
May 11, 2009 05:49 AM
kkarim
May 22, 2008 11:43 PM
