Transfer Case Install
Old Aug 23, 2009 | 10:02 AM
boostinscooby's Avatar
Im about to put my new transfer case in and was wondering if theres any tricks that you guys use to make some clearance room. Getting the old one out was almost impossible so going back in is going to be crazy hard! I am doing this on a lift.
Old Aug 23, 2009 | 01:55 PM
2theMAX's Avatar
I use the factory jack to push the engine away from the firewall. This gives plenty of room.
The jack can be placed against the ds lower control arm. GL.
Old Aug 23, 2009 | 03:14 PM
ryno529's Avatar
unbolt the lower front engine mount . put the bolt back in the the bracket on the block. have a friend use a pry bar and "lift up on the engine . There is enough play in the other mounts to get the tcase in.
Old Aug 23, 2009 | 06:10 PM
Thanks guys! Ill use both of your methods combined!
Old Aug 23, 2009 | 06:12 PM
Silver05Bullet's Avatar
its gonna be a pain in the *** GL
Old Aug 23, 2009 | 06:49 PM
ryno529's Avatar
if you loosen up that mount it is a piece of cake. It is amazing how much flex is in stock mounts the only problem is my method really only works on a lift Good luck!
Old Aug 23, 2009 | 07:32 PM
revvin9k's Avatar
Used that same method on a lift and on a garage floor. This method is great if you are using stock mounts.
Old Aug 23, 2009 | 08:01 PM
DDATuned's Avatar
I loosen the subframe. Drop it down a few inches and the t-case slides in and out with ease. Only 6 bolts. Or it might be 4 bolts and 2 nuts but its very easy. I have pulled the t-case out more times then I want to remember.
Old Aug 24, 2009 | 07:18 PM
Well I got the car back on the road. I used a little bit of everyones method. Undid the front mount, used the china jack on the ds control arm to move the motor forward and it quite wasnt enough, loosened the subframe and it plopped right in. Took a total of about 15 minutes. Finished the whole job in about an hour and a half including changing the tranny fluid, rear diff, tranfer case, acd fluid, and changing the oil in the motor. Went pretty well. Thanks once again!
Old Aug 24, 2009 | 07:39 PM
GTijoejoe's Avatar
Good job SPEEDY!!!
I too unbolted the subframe when I did mine.... Damn that thing is heavy to lift up when you are laying on the ground with the car on jack stands
Old Aug 25, 2009 | 05:18 PM
DragEvo9's Avatar
yea its not hat bad.. all you need is basic tools and about an hour
Old Aug 25, 2009 | 06:09 PM
DDATuned's Avatar
Thumbs down
Good stuff. If u ever do the tranny, take the subframe out. Makes that job easy as pie. And you can do it all alone.
Stefz
Outlander Sport
Jul 27, 2017 04:22 PM
Soupraman
Jul 5, 2016 11:21 AM
NomadMR
Mar 14, 2009 11:36 AM
evo3matt
Aug 14, 2008 04:06 PM
YeVoLuTiOn
Aug 7, 2005 07:26 PM
