Stock ECU, 1000CC injectors, Minibattery...
Old Aug 30, 2009 | 08:24 PM
Jp7's Avatar
Jp7
I recently upgraded to 1000CC injectors and have been tuned by AMS for my 3076 Kit (I have the stock IX ECU). I have had a mini-battery kit from ETS for about a year and a half.
I noticed the engine likes to crank longer before starting with these injectors after being tuned at AMS. The injectors were installed and scaled by them, as well as a complete retune for a bunch of mods I've done.
I drove the car last week, and let it sit in the garage for 6 days. I then started it the other morning and I noticed the cluster really dimmed more than usual, but it did start. I drove around the block to get gas, and it would not start - so I had a friend give me a jump. After driving it to work it had the oppourtunity to charge, and it started just fine for the way home.
I've been charging it with my trickle charger, and last night I charged it for a ride to work this morning, and it started however when I got done with work it had no power and I had to get a push start. I've pulled the battery out now.
Anyone else have problems with big injectors starting on the stock ECU with the mini battery? I wonder if 1.5 years of life on this battery is just normal. I've only had these injectors for a few weeks.
Old Aug 30, 2009 | 09:30 PM
chaotichoax's Avatar
I'd attribute it primarily to the battery
if you let your car sit for a week at a time I'd consider losing the mini battery...it simply isn't worth the trouble
Old Aug 30, 2009 | 09:38 PM
sparky's Avatar
Originally Posted by chaotichoax
I'd attribute it primarily to the battery....if you let your car sit for a week at a time I'd consider losing the mini battery...it simple isn't worth the trouble
Correcto Mundo! At least disconnect the battery if you're gonna let it sit for more than a couple of days!
Old Aug 31, 2009 | 06:25 AM
Tony1's Avatar
If your cranking voltage gets pretty low and the battery comps are wrong at those low voltages, it can have a significant affect on how the car starts.
Old Aug 31, 2009 | 10:46 AM
Jp7's Avatar
Jp7
what about trickle charging every time I don't plan on using it the next day? I was thinking of making a quick connect harness so I can just plug it in.
Old Aug 31, 2009 | 06:52 PM
EVOllie's Avatar
Thats what i do. Ive had a mini battery for 2 years now. No problems
Old Sep 1, 2009 | 12:15 PM
Jp7's Avatar
Jp7
You have the same extended cranking during starts?
Old Sep 1, 2009 | 01:04 PM
this would be a decent solution
I have a feeling you might need to replace the existing battery though...sounds like a charger might not save it
Old Sep 1, 2009 | 05:26 PM
Jp7's Avatar
Jp7
Oh the current battery is TOTALLY shot.
I have a new one coming hopefully thursday.
I found the same battery as the ETS minibattery on google.
68$ shipped.
Old Sep 1, 2009 | 05:28 PM
Blue Evo 8's Avatar
i'm running the AMS mini battery kit, and it has pooped out on me in the cold winter months if I dont use the car, but I have a battery tender which I've used on it to bring it back to life.
Old Sep 4, 2009 | 03:09 PM
Jp7's Avatar
Jp7
fresh mini battery installed today, i hope it does not die.
W_evo8
34
Jan 25, 2011 04:53 PM
sti killr
Jan 1, 2011 12:46 PM
Dragking2189
12
Feb 6, 2010 06:42 PM
tseitz123
Aug 19, 2007 08:37 PM
NocturnalEVO
May 15, 2005 07:33 AM
