More broken parts for the Bad Bish
Old Sep 3, 2009 | 10:52 AM
David Buschur's Avatar
Well we were ready for the track yesterday. I drove the car on Monday and just couldn't believe how great it felt. The car was really how I wanted it to feel. Nice response down low, good mid range, rediculous up top, I commented it has never felt this good since I've been running "GT35r" type turbos on the car. While driving the car I jumped on it and it broke up a bit. I thought it was odd because since I've been running these expensive NGK plugs I haven't had a misfire or problem and these plugs have been in the car since last year. I got on it again, same thing but a little worse. Each time I stood on it the car would break up more.
Tuesday morning I come in, change plugs, check things over and decide to just double check on the road that the plug change fixed the breaking up before the tires were changed for the track. Nope, not fixed. I brought the car back to the shop, loaded it on the dyno and attempted a pull. Something wasn't right, didn't sound right, was breaking up and I aborted the pull.
I decided to walk off and eat lunch. While I was eating it dawned on me that maybe it was, once again, a cam sensor. Grabbed a new one and installed it. Next pull the car was clean but still had the same odd noise and then I saw the coolant on the windshield. Shut the car down, walked off disgusted, it was too late by the time I realized what had been going on the damage was done.
Here is the culprit:
Here is what happens when one fails in a car that is being pushed already:
For me it gets worse. The head was also torched, but only slightly. Normally it can be welded and milled. This head though has been milled a few times, recently had the o-ring grooves welded shut and milled again and now is just not usable anymore. So, now I have to wait for a head for the car. I'd like to just take a customers but I will have to wait.
To explain what happens when the cam sensor fails. I've seen them fail completely, which is what I wish they would all do. The car quits running, you put a new one in and off you go. Instead when they start to go bad you get an incorrect RPM reading. You will get spikes in the RPM on the log. This is bad because if you are at peak torque and should have 10 degrees of ignition advance and 95% duty cycle and the sensor tells the car you are at 10,000 rpm where there is 20 degrees of advance and only 85% duty cycle..........well you see what happens.
It's been a tough year for sure. Luck has not been kind. I'd sure like to get this 8 second pass this year but the drive to get it is wearing off. Most of the time I am upset and can't think straight when the car is down, this time I could care less.
As soon as I can get my hands on a head it will be running again and then back to the track. Once this 8 second monkey is off my back I am looking forward to just driving it and enjoying it.
Expensive failure this time.
Old Sep 3, 2009 | 11:04 AM
leecavturbo's Avatar
bugger.
Old Sep 3, 2009 | 11:08 AM
mega-z's Avatar
Wow! Sorry to hear that bro.
Old Sep 3, 2009 | 11:09 AM
justa4banger's Avatar
damn...that sucks...
Old Sep 3, 2009 | 11:10 AM
Tsurugi-san's Avatar
Sorry about the misfortune --- and thanks for the heads-up about the sensor.
But that 8 second pass is still waiting for you, Dave. Go get it!
Old Sep 3, 2009 | 11:11 AM
inco9nito99's Avatar
Wow that sucks, did it fail due to heat? How can we all take preventative measures to avoid it now? Did the cam sensor shield not work as intended (atleast in your case)?
Old Sep 3, 2009 | 11:14 AM
CAD EVO's Avatar
I recently replaced my coils and plugs with a set of coils with 4000 miles on them and I still get hiccups.
Do you think maybe my sensor is going out?? Anyway to check?
OK went back to the post and will check my logs for RPM spikes.
Old Sep 3, 2009 | 11:18 AM
xX v0oDo0 Xx's Avatar
Wow, is the block able to be salvaged? Stupid cam sensor. How often do you see this severe level of damage, Dave?
Old Sep 3, 2009 | 11:20 AM
mega-z's Avatar
I think a few people have been having issues with there cam sensor.
Old Sep 3, 2009 | 11:30 AM
CO_VR4's Avatar
That sucks...
Dave, were you using your aluminium cam sensor shield when this failure occurred?
If so, what are you planning to do to protect the next cam sensor after you repair the damage?
Old Sep 3, 2009 | 11:53 AM
94AWDcoupe's Avatar
This happen to me tuning my 93/alky car on AEM. The cam angle sensor plug popped off (no metal clip). Resulted in 10,000rpm spike. alky was still flowing during fuel cut. resulting backfire was the loudest bang I ever heard working on a car. It blew the head gasket as well. dont remember it being that severe. I have not seen a metal gasket that burned yet. Sorry to hear it killed a head. That would take the wind from my sails as well.
Old Sep 3, 2009 | 12:11 PM
GST Motorsports's Avatar
David, this might make you feel better...
Old Sep 3, 2009 | 12:53 PM
TxEvo8's Avatar
Do you think this should be part of a preventative maintenance plan? Maybe change it every 60k like the timing belt?
Old Sep 3, 2009 | 12:55 PM
browningderek's Avatar
damn! i would say that head is shot! sorry for the bad luck david...
Old Sep 3, 2009 | 01:00 PM
tkklemann's Avatar
Holy crap, that looks like someone took a plasma torch to that....
