fp red..Stock cams..evo 9?????
Old Sep 9, 2009 | 06:53 AM
  #31
griffeyr's Avatar
Originally Posted by 97TSiAWD
Out of curiousity, did you turn up the boost and have it retuned after installing the Red? Or did you just have it retuned after installing the cams?
the red was installed first and then tuned....then the cams and retuned again
Old Sep 11, 2009 | 05:22 PM
  #32
sleeper04's Avatar
i currently have a stock turbo and debating on what cams, m2,s2's or s1's, i plan on going with a red in the spring... any ones input would be great. stock valve train for now wont be revving past stock redline
Old Sep 11, 2009 | 05:55 PM
  #33
will05's Avatar
Well i have the hks 280 and i am going with red and a built motor, after reading this i might want to change my mind with the cams...lol...
Old Sep 11, 2009 | 06:44 PM
  #34
vmrevo9's Avatar
Veteran: Air Force
i plan on doing a turbo first rather than cams. i plan on doing a 2.3l eventually so i can do the cams then if not i can do the cams when the timing belt has to be replaced if that happens prior to the 2.3l build. i have been looking at the BBK full as well.
Old Sep 11, 2009 | 08:39 PM
  #35
italianevo88's Avatar
i dont think anyone that ever bought cams woke up the next day and said " wow, that was a mistake" but to really get your $$ worth grab some springs and retainers if you go that route
Old Sep 11, 2009 | 08:57 PM
  #36
GaBe511's Avatar
I wanna go the turbo only route too. I don't wanna open up my engine, cuz i wanna keep the car as stock as possible but wanted a bigger turbo. So this kinnda answers my questions to what the fp red will do on a stock setup. I kinda want faster spool as well so was thinking a green. I just want to see if its possible to make 400hp with all stock engine internals and have it run reliably.
Old Sep 11, 2009 | 09:04 PM
  #37
JohnBradley's Avatar
Red before cams if you have enough for the Red. It all depends on your budget and how long you wait between upgrades. Most people will do cams before a turbo, but with the power you have now you are reasonably within 30whp of most straight pumpgas limits. A Red on the other hand is cost per horsepower definitely the better way to go.
Old Sep 12, 2009 | 12:23 AM
  #38
I never knew you could run a big turbo on these cars without doing all of what I refer to as the "supporting mods" it seems like it would be too big of a step but I guess not, anyone wanna fill me in on the details?
Old Sep 12, 2009 | 02:51 AM
  #39
IDRINKV8'S's Avatar
I made around 430 whp on a hearbreaker dyno (d.d) with a 1.0 correction factor which equals to a little over 500whp dyno jet number stock cams,stock block,on meth 30psi...the red is a nasty little stock framed turbo also sounds like a jet coming.
Old Sep 12, 2009 | 07:05 AM
  #40
does the red have a lot of lag?
Old Sep 12, 2009 | 07:27 AM
  #41
cij911's Avatar
Well from most of the threads I have seen re: the FP Red it appears to hit peak Tq ~500 - 1000RPM after a stock 9 turbo. That said, the numbers will be bigger at peak and will hold better throughout the rest of the RPM range.
Old Sep 12, 2009 | 08:04 AM
  #42
IDRINKV8'S's Avatar
mine gets full spool at 4,200 rpms and keeps pulling hard to redline...
Old Sep 12, 2009 | 08:56 AM
  #43
4200 isnt bad at all. I want a red! haha
Old Sep 12, 2009 | 01:04 PM
  #44
RockmanX's Avatar
i say get whatever one you have the money for at the time. if you have red money get it now and knock it out if you have 600 get cams sounds pretty simple to me. lol as i stated earlier you can kill all this lag talk fp red supporting mods 2.3 shortblock
Old Sep 12, 2009 | 03:11 PM
  #45
hah ill never have money for the 2.3, hows the driveability of the stroker
FaceMe
Nov 13, 2016 02:30 PM
chris the man
May 13, 2013 09:37 PM
zeus1
For Sale - Cars For Sale
18
Apr 4, 2012 04:30 PM
nonschlont
Oct 1, 2010 11:25 AM
Svendiesel
15
Mar 22, 2010 10:23 AM
