AEM Tru Boost Big Turbo Guys Using the 5 Bar External Sensor, Questions Please???
Hi Guys-
We are finally starting to tune my car and I have the AEM Tru Boost with 5 Bar Upgrade External Sensor.. I'm running a GT35r with all supporting mods including a tial 44mm external wastegate.. The target boost I want right now is around ~26psi .. So obviously I want to hold that value all the way to redline without any spikes and taper.
Please Post up your Boost Setting A and/or B (% percentage duty cycle) and what you have your Spring Pressure (SPR) some times called Waste Gate Crack Pressure (gAE) at.. Some people are having luck with setting this value closer to ~3 .. Others higher to their wastegate spring (which would be closer to 20 psi in my case since that is what kind of spring my Tial 44 has in it).
Thanks so much guys!!!!
The best way would be through trial-n-error. Every application is different and the results will not be the same.
The best way to set the gAE is through testing. Start with the lowest setting and keep raisng the value untill you have the best response without boost spiking. I've seen one application work great with a value of 5 and another with 10. That value depends mainly on the actual WG spring rate and the response of the turbo.
Also, any one else with experience that can give me an example of their current settings, that would be great.. along with the "A" and "B" boost setting duty cycle % percentage. Mine is set to A40 (%) right now and the gAE is at 4.0 and it seemed to spike 29psi and taper to 26.. This is also the 5 bar sensor keep in mind. thanks
bump.. this thing is REALLY frustrating.. Has any one with a 35r type setup even been able to tune this thing and make it so it is consistent and actually holds the boost all the way to redline? this is ridiculous i pay this much for a boost controller/gauge and it can't even be consistent and work correctly
My numbers are totally different, I'm running 33psi, with a 1.4bar wastegate spring, crack pressure is 19.5, boost A is 44, and boost pressure B is 45. I have air/water intercooler and 46" less intercooler piping. You just have to take your time and make small adjustments.
I am not running high boost I am still on stock turbo. My crack pressure is set somewhere around 10 and the duty cycle is at 57. This gives me a spike o 21 but I hold around 18-19 psi until the ix turbo runs outo breath. Hope this helps, from what I read its trial and error every car is gonna be different.
using other peoples settings might get you close, but close doesn't matter
re read what crispeed said
Boost3dxEvO
Oct 8, 2009 06:27 AM
