Cam upgrade worth it???
Old Sep 7, 2009 | 06:45 AM
raiceboi697's Avatar
there are lots of things that you need for cam upgrades, but talk to a tuner and tell him your goals. i would recommend the kelford or the comp cams
Old Sep 7, 2009 | 07:09 AM
bbyevo8u's Avatar
^^ like what springs
Old Sep 7, 2009 | 07:19 AM
eldiablo79's Avatar
Originally Posted by Eartears
I'm currently running a 37r on built 2.0 with all the supporting mods. I'm having a 6262 installed next week. Im currently running an HKS 264/272 cam setup.
Would it be worth while to go with a set of Kelford/GSC 272's or 280's? It will not be tracked, just a fun street toy. Im guessing its probably not worth it, but just wanted to hear some opinions. Thanks!
I had GSC S1 272 cams, with my stock turbo and I loved them. Then I just recently upgraded my turbo to the HTA GT3586. I really didn't have to, but to really get the maximum potential of the turbo I upgraded the cams to GSC S2 cams. Plus I needed to upgrade the springs and retainers for my new cams. It was a little costly, but it was so worth it. You would definitely feel and hear a difference especially since the HKS cams are not very aggresive.
Old Sep 7, 2009 | 07:31 AM
grillpt's Avatar
I would go with a set of Kelford 272's, 280's or GSC S2's. Dual valvesprings and retainers are a must. Is the head on the car orig, or has it been ported? You may want to consider doing that as the oe head can't flow enough for some of these larger lift cams. Good luck with it.
Old Sep 7, 2009 | 07:32 AM
eldiablo79's Avatar
Here this might help: https://www.evolutionm.net/forums/ev...-cam-test.html
Old Sep 7, 2009 | 07:34 AM
eldiablo79's Avatar
Yeah those are real good suggestions. As you'll see in the cam test. I have GSC S2 and my friend has Kelfords, and they both run great. Awesome cams.
Old Sep 7, 2009 | 07:58 AM
Eartears's Avatar
Thanks for all the input guys! Im currently running Ferrea Valves, Springs (not sure if dual) and retainers. I just bought this car and the owner was unsure of a few things. He said the heads may have some mild port work if any at all.
Old Sep 7, 2009 | 05:32 PM
Eartears's Avatar
Well I've settled on a set of GSC S2's. Can't wait!
Old Sep 7, 2009 | 06:08 PM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Even your old setup would benefit from Kelfords or GSC's
manthny18
Jan 25, 2017 10:27 AM
SimongX
Jun 28, 2016 09:58 AM
jaysonsyl
21
Dec 11, 2012 06:21 AM
Knightracer
21
Jul 7, 2010 03:27 PM
Kracka
30
Dec 19, 2008 06:06 PM
