TBE fail ...
Old Sep 8, 2009 | 08:11 PM
19DB794's Avatar
Oh and heres a how to if you decide to replace the o2 housing: https://www.evolutionm.net/forums/ev...sing-pics.html
EvoJoeIX's Avatar
Originally Posted by fugiwara
TBE stands turob back exhaust, therefore you want to replace your stock O2 housing anyway in order to have a true TBE set up. Buy an ebay O2 housing and you'll be good to go.
true but if you buy a TBE, they never come with a o2 housing since thats considered part of the turbo
Old Sep 8, 2009 | 08:12 PM
Hi Im Vinh's Avatar
Originally Posted by evo unknown
if ur doing a tbe, DO 02 housing. it is so worth it. ebay O2 housing = $50. many evos r running the ebay O2 and r very happy with it.
time consuming job. take the hot side of the turbo off and re tap it for a new bolt. well worth it in the end though.
Sorry for the newbie question , but why must the hotside be taken off and re-tapped ?
Old Sep 8, 2009 | 08:13 PM
EvoJoeIX's Avatar
if you do it right you shouldnt have to do any retapping....
mine went on smooth
Hi Im Vinh's Avatar
Thank you sir , I did read up on that link before I made this post lol . The work involved in that link is what makes me not want to install the o2 housing myself .
Old Sep 8, 2009 | 08:15 PM
19DB794's Avatar
Trust me, it looks intimidating but its a pretty straight forward install. Just make sure you have a good tool set and take your time. Like I said, I just removed the entire turbo to make the install much easier but it doesnt mean you have to. You could remove the hot side like some people mentioned. It took me and a friend about 14-16 hours to install an O2 housing, FMIC with new pipes, boost controller and a couple other misc things like my Ralliart Lip etc...
Hi Im Vinh's Avatar
Originally Posted by LOVEBOOOST
check out shearer look at this vendor announcements u should see it he made a thread bout today
What company is he under ?
Old Sep 8, 2009 | 08:16 PM
EvoJoeIX's Avatar
just remember to take out the radiator.... makes it wayyyy easier then trying to do it with it in
Old Sep 8, 2009 | 08:18 PM
Hi Im Vinh's Avatar
the thought of taking out the radiator is what scares me :X
Old Sep 8, 2009 | 08:21 PM
19DB794's Avatar
Lol, the radiator is probably the simplest thing to do out of the whole procedure. I just removed the lower hose and took the cap off and then its just the 2 bolts on the brackets up top and disconnect the top hose and just pull it right out. Dont forget to disconnect the fan too. My biggest concern would be the o2 sensor but surprisingly mine came off pretty easy.
Old Sep 8, 2009 | 08:28 PM
evo unknown's Avatar
i meant retapping the hotside where the bolts for the O2 housing insert. I thought u said one broke off there. that happened to me because of just simple time and rust on that area and that is how i fixed the problem.
as for the ebay O2 housing not lining up, i never heard that. It fit perfect onto the hotside part of the turbo and lined up perfect on the aftermarket Apexi downpipe I installed it on. I did reuse stock gasket and donut gasket and many miles later, it is still great.
I did the job with the radiator in because I had just done a flush and did not want to have to do it again. It is doable with the radiator in, I may have bent like 4 fins which I was able to bend back, although it may have been easier with the radiator removed.
Hi Im Vinh's Avatar
Off topic question : anybody know of any good shops that deal with evos in houston or near that can do a o2 install ? lol
Old Sep 8, 2009 | 08:30 PM
PB blaster is a god given item lol. spray as much as u can the night before and the day of and right before. made most bolts very easy to remove.
all in all the job took maybe 7-8 hours, but that included the extra step of having to retap the hotside because of the broken bolt.
and yes put antiseize onto everything upon reinstallation.
Old Sep 8, 2009 | 08:31 PM
Hi Im Vinh's Avatar
So how do you like the o2 housing? I read in one of the stickys that an aftermarket o2 might cause boost creep
Old Sep 8, 2009 | 08:33 PM
Hi Im Vinh's Avatar
Got it , tons of pb blaster and use anti-seize to ensure easier disassembly
