hard to go into gear?!
Old Sep 13, 2009 | 12:19 AM
aguita's Avatar
Hello...
I just bought a new evo and I noticed when im in neutral and want to go into gear it get hard to shift...No matter which gear I choose,no grinding at all just hard to go, but once in gear it shift increadible smooth thru all gear up and down shift just when in neutral..I was told by the Previous owner that the car has a twin disc exedy, which I doubt since i was told that twin disc make noises, this clutch do make noises when letting the clutch out and when shifting..isnt supposed to a twin disc to make noise when u press the clutch in??
thanks!
Old Sep 13, 2009 | 12:19 PM
Huntington MR06's Avatar
try double clutching to get the gear in
Old Sep 13, 2009 | 12:24 PM
From 3 to E's Avatar
i dont remember any twin disks making noise when engaging the clutch, however they will make a ton of nasty sounding noises when you engine brake.
my 8 is hard to get into first. no grinding or anything, but you have to REALLY want it in first, especially if your rolling (1-2mph, such as a stop sign)
Old Sep 13, 2009 | 04:03 PM
aguita's Avatar
my problem is when Im on a stop light or whenever I want to go into gear!
Old Sep 13, 2009 | 04:53 PM
delongedoug's Avatar
They definitely make a coffee grinder-like sound when you push the clutch pedal in, whether stopped or shifting gears. At least the one's I've come across do.
Old Sep 13, 2009 | 11:49 PM
aguita's Avatar
well mine does make the sound on deceleration and shifting..Does anybody knows why is hard to get into gear?
Old Sep 14, 2009 | 12:01 AM
churbo's Avatar
I have the exedy hyper single clutch installed in mine and I have the same issues as you have. I have noticed if I put it in gear before I start it I have no problem getting going. Then if I push the clutch in as I'm rolling up to a stop then leave the clutch pressed in and shift into first I have no problems. If I put the car in nuetral and let it sit for a minute then it doesn't want to go into gear. Then I have to turn it off put it in gear and start it again to get going. It's weird and I am getting a new clutch when I get back from this deployment. Oh and mine is noisey under decel as well, it's really annoying.
Old Sep 14, 2009 | 07:35 AM
aguita's Avatar
this is the issue! but i can go into gear with the car running just with a some effort! bump for solutions!
Old Sep 15, 2009 | 12:41 AM
churbo's Avatar
I posted up here before about it and really didn't get any answers. I've tried adjusting the clutch, took it to a shop and they said it didn't need adjusting. That's why I just finally came to the conclusion of getting a new clutch installed. I don't like how loud the exedy is anyway. Hopefully someone can figure it out though.
Old Sep 15, 2009 | 09:42 AM
adjusting the clutch only pertains to engagement points.. the only way that would help is if your clutch was so far out of whack that the clutch was not fully engaged at the point your pedal was at the floor.
going back to the first reply, when im coming to a slow roll or rolling stop i blip the gas just a hair and it seems to help get in first gear. otherwise it will go in, but you have to brute force the hell out of it to get in.
roni4g63
May 21, 2020 07:43 PM
jam05pr
Jul 20, 2010 10:31 AM
TitanMotorsport
Oct 22, 2009 10:09 AM
8ASTI
13
Jun 12, 2005 09:52 PM
evosevengsr
May 20, 2004 01:51 AM
