Whining..?!?
Old Oct 1, 2009 | 07:12 PM
  #46
evo unknown's Avatar
i'm going to have a local friend check it out for anything abnormal. i am due for awd service in about another 2k miles
Old Oct 11, 2009 | 09:06 AM
  #47
Taimur's Avatar
Originally Posted by MitsuJDM
And one that might be starting to go bad:
http://www.youtube.com/watch?v=7zz9J...eature=related
I launched the car last week with a little wheel hop and nothing happened then and for no reason it just started to sound like this last night. I only hear it in 5th gear (no other gears) just cruising or during decel.
Has anyone really confirmed if this is caused due a bad TC or just normal.
Old Oct 14, 2009 | 12:54 PM
  #48
yes, that ^^ is for sure TC death whine
Old Oct 14, 2009 | 01:04 PM
  #49
BluEVOIX's Avatar
Mine makes the same sound. Only during cruise or decel, it goes away in acceleration.
I put the car on jack stands while giving it gas and it seems to be coming from the transmission. It was hard to tell because there was no load on the car when lifted. The transfer case did not make any noise. But using a screwdriver as a stethoscope medium, it seems to be coming from the transmission. I think it might be the TOB but I am not certain.
I will find out this weekend since I'm changing the clutch and putting in shep trans.
Old Oct 14, 2009 | 04:01 PM
  #50
Taimur's Avatar
Aww... This piece of crap is weak. Stock clutch car making 320whp and never dig launched it only a few roll launches with all 4 wheels spinning.
Old Oct 14, 2009 | 04:04 PM
  #51
tscompusa2's Avatar
no it just needs maintained really well... you need to keep changing fluids every 15k or so.... im making 451wtq and mines fine and i launched 10 times so far and when i launch i spin so hard it smacks against the rev limiter.
TC is the weakest link tho in entire drivetrain of evo.....
Old Oct 15, 2009 | 08:04 AM
  #52
Taimur's Avatar
Let us know if you still hear the sound after changing the clutch and trans.
Old Oct 15, 2009 | 01:44 PM
  #53
evo8inla84's Avatar
You're a luck camper if its not the t-case cuz I just dropped a sht load on that sucker. I had an 03 and I went with an 04 tcase w/lsd so it was a good turn out in the end but i dropped $$$$
Old Oct 16, 2009 | 07:33 AM
  #54
Taimur's Avatar
Update!
I just drained the Tcase fluid last night and it was completely black and full of metal flakes.
Conclusion: TCASE is toast
EVO(boss)
12
May 10, 2016 06:39 AM
booosted
Sep 2, 2015 05:38 AM
LTEDDER
22
Apr 8, 2014 02:43 PM
armysoldier1073
Feb 3, 2012 07:11 AM
EvoDom
11
Jun 5, 2010 06:44 AM
