Recirc BOV's above 28PSI, info request
Old Sep 21, 2009 | 01:45 PM
  #46
mrdecrypter's Avatar
30 PSI - Synapse - Recirc.
Sounds like a thunder crack when off throttle at that PSI. Holds perfectly fine.
Originally Posted by ronitlancer
Sort of hard to search for, but I am trying to find info on people running recirc BOVs with 28PSI or higher. How its holding the boost, if any sort of leak-stop/etc was needed. And how their driveability is.
I don't wanna go VTA cause the sound is just too much for me, and generally has worse driveability then Recirc.
Can users with a Recirc running 28+ give me some feedback on the sound/driveability/boost-holding of thier BOV and what type it is. Thanks
Old Sep 21, 2009 | 01:51 PM
  #47
kmcconn9's Avatar
Synapse...
Old Sep 21, 2009 | 01:58 PM
  #48
ronitlancer's Avatar
Well then hopefully i made the right decision
Thanks again everybody for your time to post in my thread, sometimes it is very hard to get people to respond and I was very pleased with all the feedback. Thanks a bunch!
Old Sep 21, 2009 | 02:20 PM
  #49
Originally Posted by Tsurugi-san
I'm recirculating the Synapse BOV with 39 psi on the Red.
Rock solid!
C port to the turbo outlet pipe + A port to the intake mani + B port blocked.
What does blocking port B help with? I am running the same as you accept with A+B on the same vac line off the intake mani.
Old Sep 23, 2009 | 01:32 PM
  #50
Would like to know also for when I receive mine.
Old Sep 23, 2009 | 02:35 PM
  #51
ETS Michael's Avatar
I need to test out a synapse!
Michael
Old Sep 23, 2009 | 04:40 PM
  #52
whtrice's Avatar
Veteran: Air Force
What turbo are you running ?
Old Sep 23, 2009 | 04:51 PM
  #53
Dorikun's Avatar
Let us know how it turns out, post pics etc! Sounds nice, I'd like to stay recirc as well.
Old Sep 23, 2009 | 06:03 PM
  #54
jamevo8's Avatar
mine Synapse will be here tomorrow yay
Old Sep 23, 2009 | 09:07 PM
  #55
Stock, will be running a bigger stock-frame turbo as soon as the BBK-XL and FP Black come out.
Old Sep 23, 2009 | 10:38 PM
  #56
Tsurugi-san's Avatar
With my setup (see sig) I would get part throttle flutter at low load in 3rd and up with the B port open. While I was testing my install I kept trying different configurations to see if I could find a "magic bullet" to halt my part throttle surge. One time, I simply pulled the line off of port B, plugged it, and reinstalled the line. The result was much less throttle surge --- not eliminated, just much less. I'm still toying around with the setup and will try to perfect it.
Thanks for asking!
Old Sep 24, 2009 | 08:08 PM
  #57
whtrice's Avatar
Veteran: Air Force
So you are basically just running port "A" and "C" then? Had any success with adjusting the preload adjustment?
My application is with a FP "green" on E-85. I have been experimenting with solutions to get rid of part throttle flutter. I found for me that using port "B"
with a vacuum restrictor I bought and port "A" open works best so far. I do use port "C" for boost signal and have the preload screw all the way in almost.
I think a turbo with more lag...(ie red.....GT35....) might require a different set up.
Thanks for asking!
Old Sep 24, 2009 | 10:51 PM
  #58
Mautofied.IS300's Avatar
Don't know if someone said this already, but if you get a Forge RS make sure you do some trial and error in adjusting the spring rate. I run it and love the fact that you can turn a dial to adjust the spring rate with a big, easy to use knob instead of actually switching springs which have dedicated rates 8/11...I have my RS set perfectly so I get no flutter, and it doesn't hiccup at low boost. I also switch it around every once and awhile to change the sound it makes (can be run either way).
-Will
Old Oct 11, 2009 | 10:45 AM
  #59
whtrice's Avatar
Veteran: Air Force
Just a note regarding the Synapse BOV. I had mine originally mounted in the typical vertical Evo fashion. Had part throttle flutter issues with it using ALL hose port and preload spring adjustment settings. This weekend I reloacated it so that it is mounted in a more horizontal config and flutter has all but disappeared. Since it is a cylinder design I suspect when mounted vertically gravity was effecting the shuttling of the cylinder during use. Horizontal mount is as designed. Holds boost like crazy.
Old Jan 9, 2010 | 07:44 PM
  #60
mayberry's Avatar
I bought a Synapse valve yesterday to replace the forge that came with the car. Every way I tried installing it make the car run terrible and I got awful flutter. So I bit the bullet and re-installed the Forge and it idled as it should and drove a lot better. But the forge just doesn't hold the boost like the synapse did.
Maybe it's because I couldn't figure out the right way to install it with my Hallman manual boost controller. I keep searching around here hoping to find the magic answer but we'll see.
