Recirc BOV's above 28PSI, info request
Old Sep 19, 2009 | 12:17 PM
  #31
Ted B's Avatar
With the Synapse, there are no spring changes, no adjustments, nothing. You just put it in and go. We put 40psi to mine and it is dead silent - no leaks.
Old Sep 19, 2009 | 12:21 PM
  #32
digitech's Avatar
The synapse is great, but if you live in a emission **** state like california seeing the synapse is a trip to the smog ref and heavy fee's the samco bov in black or forge in black. Are good if your going for stealth since the synapse is somewhat chunky.
Old Sep 19, 2009 | 12:25 PM
  #33
McLaren F1 2003's Avatar
Originally Posted by whtrice
Depends on what application you use it in. Are you basically a stock setup or do you have a hardpipe for a UICP? For basically stock set ups you will require a recirc 1.25 inch adaptor piece to plumb it into your UICP hose. I tye wrap all the hoses and a "T" fitting is required to plumb into the boost signal line from your turbo outlet pipe. This is the one that goes to my boost control solenoid.
yes, im still using the stock uicp and bpv
luckily we dont have to worry about that here haha
i will look into the synapse when i switch to e85 and start running more boost
Old Sep 19, 2009 | 05:06 PM
  #34
ronitlancer's Avatar
I am thinking of going with Forge simply cause it is black and stealth, but all these "Gurus" talking about the Synapse is making me wonder. Although my engine bay is pretty stock looking.
Old Sep 19, 2009 | 07:46 PM
  #35
mrfred's Avatar
Read up on the Forge. It holds boost fine, but it often causes bad flutter.
Old Sep 20, 2009 | 01:34 AM
  #36
the Synapse honestly confuses me
Old Sep 20, 2009 | 02:14 AM
  #37
I did some more research on it, seems like it has flutter/jumpy issues just like any of the BOVs. half of the people responded with 100% no problems, and the other half said they get some surge, a lot of flutter on the highway, and a lot of bucking in part-throttle situations.
So what makes the Synapse better?
Old Sep 20, 2009 | 02:32 AM
  #38
SpoolinUp's Avatar
Silver Sponsor
What PSI are you running? Hows the driveability, what made you choose the Perrin?
Oops I mis spoke. I am running the Samco. Only about 25 psi, but the drivability is a bit better and I hate the sound of BOV's (its as quiet as stock and fits like stock). It is known to hold higher psi well. Running medium spring. If you have an aftermarket ignition there is no cruise flutter as well!
As far as thje Forge, I suspect that it only gets terrible reviews because the normal owner is too lazy to scroll through the million possible settings to get it tuned properly. It would only flutter a tad during cruise on the girlfriends car.
__________________
-Matt- http://www.SpoolinUp.com
"Performance without the Price Tag"
Old Sep 20, 2009 | 07:16 AM
  #39
Ted B's Avatar
It doesn't flutter, creates no idle issues, needs no adjustment, and won't leak. There are three possible vacuum port arrangements. Find the one that works best for you (do a search) and you're done.
Old Sep 20, 2009 | 01:40 PM
  #40
In the two major Synapse threads I found, there were quite a few people experiencing both flutter and bucking.
Old Sep 20, 2009 | 02:03 PM
  #41
Evoryder's Avatar
Forge RS. I have tried MANY and the adjustability makes a huge difference(holds boost great)
I haven't tried the synapse, however, it does sound good.
Old Sep 20, 2009 | 02:17 PM
  #42
fromWRXtoEVO's Avatar
Sort of hard to search for, but I am trying to find info on people running recirc BOVs with 28PSI or higher. How its holding the boost, if any sort of leak-stop/etc was needed. And how their driveability is.
I don't wanna go VTA cause the sound is just too much for me, and generally has worse driveability then Recirc.
Can users with a Recirc running 28+ give me some feedback on the sound/driveability/boost-holding of thier BOV and what type it is. Thanks
Please read, I created this topic a few years ago specifically with the info you are looking for:
https://www.evolutionm.net/forums/ev...-26-27psi.html
Carlos
Old Sep 20, 2009 | 02:19 PM
  #43
Ted B's Avatar
There are three possible ways to connect the vacuum ports. Find the best way for you, and it should be perfect. Those with smaller turbos tend to use a different setting than those with larger turbos, etc. I found perfection with A+B to the manifold and C to the UICP.
I had the Forge RS and ditched in favor of the Synpase.
FWIW, I realized two issues with the Forge design. The first that the tightest setting is required for over 30psi boost, and Forge states that ~34psi is the maximum it can hold regardless. The second is I found that setting gave the poorest overall drivability. The Synapse won't leak at 40+ psi and gives absolutely transparent drivability.
Old Sep 21, 2009 | 01:04 PM
  #44
I went ahead and ordered the Synapse in favor of you Gurus
We will see how it works for me.
Old Sep 21, 2009 | 01:11 PM
  #45
Tsurugi-san's Avatar
I'm recirculating the Synapse BOV with 39 psi on the Red.
Rock solid!
C port to the turbo outlet pipe + A port to the intake mani + B port blocked.
