Evo won't take gas
Old Sep 17, 2009 | 03:01 PM
evo082006's Avatar
Evo won't take gas
Help..I have been having this problem for about a month now, and its driving me crazy. Every time I go to fill up, the car takes a little gas then the pump clicks off. I have to basically baby the fuel in the tank. I have tried everything from barley having the fuel spout in the car to pushing it far down the fuel hole. I freaking stumped. Im pretty sure it has to do with the retarded evap system, but not sure. Looking for advice and opinions. Thanks.
Old Sep 17, 2009 | 03:04 PM
MitsuJDM's Avatar
Do you continue to go to the same gas station, or is this happening at different gas stations?
Old Sep 17, 2009 | 03:06 PM
D-Mon3y69's Avatar
i sometimes get that to, i just have to put the pump on the slow setting and it doesn't do it after that.
Old Sep 17, 2009 | 03:14 PM
evo082006's Avatar
I have been having the symptom at multiple gas stations..
Old Sep 17, 2009 | 03:34 PM
mini_evo's Avatar
It is the EVAP system. I can't remember WTF it is exactly that causes it, but I've seen threads like this within the past 6 months. Sorry I couldn't give deffinate answer's, but better than nothing right?! lol
Old Sep 17, 2009 | 03:42 PM
JakeTheVIII's Avatar
It's happened to me before, I just pump slower. Some of them seem to flow too much when fully depressed. I guess that's what you've been doing though.
Old Sep 17, 2009 | 03:44 PM
evo082006's Avatar
Should I tear the evap system out and smash it? I have already disabled the EGR test through the ECU. Also I live in GA, we have no emissions tests where I live.
Old Sep 17, 2009 | 04:01 PM
evo082006's Avatar
I found where Frosty removed the whole system, and I am going to do this as soon as I acquire an EGR block off plate. If you do have a better idea let me know. Damn PC load letter..
Old Sep 18, 2009 | 01:47 PM
barneyb's Avatar
Sounds like the leveling valve is stuck shut. It closes off the venting, gas backs up the filler pipe shutting off the dispenser before the tank is completely full - this is normal operation. So, you can imagine what happens if the valve is stuck shut.
Old Sep 21, 2009 | 07:01 AM
evo082006's Avatar
How do I fix this, will I need a new leveling valve, if so will have to D&A the fuel tank.
Old Sep 23, 2009 | 05:37 PM
evo082006's Avatar
Fixed the issue. I disconnected the vacuum line the goes from the leveling switch to the charcoal canister, and it took gas not problem. I believe the charcoal canister is junk. Probably going to remove the evap crap all together. Thanks to Barneyb for the help..
Old Sep 24, 2009 | 11:24 AM
sk8terdude929's Avatar
I would try to replace the check valve in the fuel filler neck, mine does the same thing. but if i pump half speed it works fine just takes forever. i have had this issues on other cars at work and replacing the valve or the full filler neck (has valve in it) has fixed this.
Old Sep 24, 2009 | 11:30 AM
yahu's Avatar
+1 on pumping a little slower when it happens to me. Otherwise I jam the filler in and wedge it down relatively hard and it usually works. Threatening the pump whilst cursing also seems to help (me, anyway).
Old Sep 30, 2009 | 09:50 PM
harrisonk531616's Avatar
I just had the problem tonight...haha...so whats the remedy...just pump slow?
randomdriver
Oct 29, 2013 10:19 AM
Nasty Evolution
Jun 22, 2011 09:56 AM
dsevo
Dec 31, 2005 08:02 AM
snapb1
Aug 10, 2003 10:06 AM
