Load pop heard on canyon run
I was taking a canyon run tonight down los flores. I took a left hand turn pretty quick and heard a loud pop come from the right back side. I stopped the car and checked the tires but they were all ok, and there werent any metal parts in the road. I drove over some speed bumps by my house no noises and took the last two turns by my house fast and the car was normal. Any ideas as to why it would do this? I think I either hit something in the road or the car back fired.
Originally posted by Vanilla Sky
were you shifting hard? could have been the differential bang
(edit: not just shifting hard will make the sound, but not shifting hard "correctly")
When you shift HARD and release the clutch very quickly, you will get a slight "bump" sound from the diff. Think of it like if you had another 150hp, you'd probably break traction at 3/4 corners.
Originally posted by IzenGreyEvo7
It's almost impossible for you car to back-fire if you have a catlytic converter.
As I said, I'm basically auto-technically illeterate, but it doesn't make sense that modern cars can't back fire, especially with bad gas.
Re: Load pop heard on canyon run
Same thing has happened to me 2 times, I think it's a sway bar poping or something, I never does it on the track and I don't think it's a rock because it only does it when you turn really sharp. Same thing when I pull in my drive way sometime I will hear a little noise back there.
It was just your rear end breaking apart because of the rust. No big deal.
Mitsu will take care of you, they love supporting us evo owners with top priority customer care....especially if it's after a spirited drive.
Wow. I thought I was the onely one. I have a cusco sway bar and time to time I will hear a loud popping sound, but never at the track. Maybe it has to do with turning and going of a bump. By the sway the sway is not loose or installed uncorrectly.
Well at least I know others are getting the same poping so its prob just some thing normal the car does (I hope)
is just the lug wrench bouncing against the trunk floor
Mine does this too. It is just the cream colored bag with the lug wrench and jack handle in it hitting the cardboard trunk floor. It is the only think in the trunk not bolted down. I took mine out and went for a ride on same road and no bang. Put it back in and bang. It only does it on certain turns and G-loads.
Chad.
Chad.
MustachexBoy
Dec 20, 2011 12:13 PM
Dbar4G63IX
Jul 24, 2010 03:56 PM
Boni
26
Jun 15, 2005 11:23 PM
