Help! Cant get transfer case out!
Old Sep 20, 2009 | 09:10 PM
hastyman14's Avatar
i have a evo 8 and i need help taking the transfer case out. it seems to be stuck. i have taken the driveline, axles, transfer case bolts out and it only slides about an inch out and seems to get stuck on somthing in the trans. if u have any knowledge anything weill help...
Old Sep 21, 2009 | 12:00 AM
moevo9's Avatar
On my evo ix I had to take the half shaft out of the tranny on the drivers side. Before you take the half shaft out put a bolt back in the tranny to hold it up or the tranny will just fall. I am guessing that you are trying to take the tranny out. Evomoto has a how to but I can't remember if its for a evo 8 or 9. Hope this is some help.
Old Sep 21, 2009 | 01:22 AM
evoyrrah's Avatar
yep passenger side half shaft needs to be pulled out.....screw a bolt in there and use a slide hammer to get it out
Old Sep 21, 2009 | 03:47 AM
moevo9's Avatar
Maybe on an 8 you have to pull the passenger side as well but on the 9 I only had to pull the drivers side. FYI if you don't have a side hammer go and get one before you try and pull it out it will save you a lot of time and trouble.
Old Sep 21, 2009 | 07:24 AM
lemmysports2's Avatar
these guys are right, ihave an 8 and had to pull both half shafts. get a slide hammer and an m8x1.25 bold to thread into the half shafts.
i know your not doing a clutch job but heres a write up with pictures that helped me.
http://evomoto.com/tech_articles.php?tech_article_id=27
Old Sep 21, 2009 | 07:27 AM
oh and good luck getting the tc out of the car with the motor and the tranny still in. i think you either have to remove front subframe or move the engine foward in the engine bay to squeeze it out. just be prepared.
i think theres also an article on just removing the tc in the how to section if you search there
Old Sep 21, 2009 | 07:30 AM
dubbleugly01's Avatar
if you have both axles out, and it's just stuck, if you put one hand on the drive shaft and one hand on the tcase, you can get quite a bit of extra leverage to wiggle it free. Up down, left right, it should come out.
Old Sep 28, 2009 | 05:22 AM
FL_SilverEvo8's Avatar
It's easy getting out the TC. I took out both half shafts(with a slide hammer). Undo the bolts that hold it on the tranny (I think it is 6 of them. 3 up top and 3 on the bottom). Take off the tail housing on the back of the TC. Slide the TC out of the way and put one bolt back in the tranny (I did the bottom bolt near the fire wall). Get a wrachet strap hook it to that bolt and hook it the front bolt that holds the center cross member(I think that is what it is called) Now wrachet it pulling the motor froward make sure you have someone holding the tc it will fall out. Their you have your TC out.
Olms2468
Oct 7, 2013 03:37 PM
teameditevo08
Dec 29, 2012 04:53 PM
jcreager82
11
Aug 21, 2011 12:40 PM
rgonyer
Jun 29, 2010 11:29 PM
typac69
Mar 5, 2005 05:20 PM
