Clutch engagment changed on me.
Old Sep 21, 2009 | 11:28 AM
BlackSE's Avatar
So I got an ACT heavy duty sprung 6 puck clutch this summer cuz the stock one went out. After it was installed I bled the clutch line and adjusted the clutch engagment point to be fairly low. Over a few weeks I've noticed that the engagment point has risen to the top of the pedal. Also last week I didnt drive the car for a day, so the next morning when I get in the clutch pedal is halfway down, and I had to pull it up for it to feel normal again. What could this be? Should I just bleed the clutch line again and try readjusting it? or could it be a problem with the seal rings on the master or slave cylinder? Also I am using the stock rubber clutch cable, could it have expanded and is that what is causing this?
Old Sep 21, 2009 | 02:58 PM
allinevo's Avatar
I would bleed the clutch again. Note: it is somewhat difficult with the clutch restrictor in but if you have access to a pressure bleeder then it is no problem. I can almost be certain that you have air in system.
Old Sep 21, 2009 | 03:01 PM
meckert's Avatar
yep ^^, have you checked fluid level and your slave cylinder to be sure its not leaking
Old Sep 21, 2009 | 05:20 PM
BlackSE's Avatar
would it help if I took out the restrictor pill and then bled the clutch line?
Old Sep 21, 2009 | 06:16 PM
t-revzr's Avatar
I had a problem with mine sticking in half way too. For me it was a bolt fell out of my slave cylinder! Maybe check the bolts too??
The_Police
Apr 6, 2016 07:05 PM
bnr34rb26dett
10
Jun 5, 2012 11:47 PM
tephra
Dec 13, 2009 06:39 PM
idriveanevo
Feb 28, 2009 02:39 AM
Toxin
16
Aug 28, 2008 03:45 PM
