Tranny Install
Old Sep 25, 2009 | 03:07 PM
thedru13's Avatar
Tranny Install
Ok.. I need to re install the tranny. I took it out but want to see if there was any tricks to putting it back in. Was a ***** to take out I have heard its even harder to put back. So any tips tricks or thoughts would be appreciated......
Thanks.
Old Sep 25, 2009 | 03:26 PM
typac69's Avatar
you working off the ground im assuming... use a jack and work its way up.. also one extra set of hands is always nice.. then put it on your chest and muscle that back up
Old Sep 25, 2009 | 03:37 PM
thedru13's Avatar
Yah working off the ground. I have a low trans jack so tranny is on that. Also when i took the trans off i had to loosin the tcase banjo bolt and lost alot of fluid. Do i just refill with the ATF fluid in that reservoir by the driver side headlight? What kind of ATF fluid should I use?
Old Sep 25, 2009 | 05:24 PM
insanechief's Avatar
Good luck..I didnt do the tranny but the dang T-case sucked enough. Yes get your buddy over there to help you.
Old Sep 25, 2009 | 06:37 PM
kiley_sean's Avatar
You can buy the ACD fluid at the dealer for lik 5-6$ for a bottle (it's less than a quart, IIRC). I can't remember what type of ATF it is. I'm sure you can search that up if you want to buy it at an autozone.
Here..did a search for you:
Fluid:
https://www.evolutionm.net/forums/ev...iii-fluid.html
ACD bleeding:
https://www.evolutionm.net/forums/ev...eding-acd.html
Just remember to fill the reservoir up all the way to the top before bleeding (you will need a 2nd person underneath). After it's bled real good (all air out), bleed it some more just to get the fluid level about a 3/4" below the max line because the fluid level will rise after you drive it. You will probably have to use a turkey baster or straws to remove some of the excess fluid the next day.
To bleed it, turn the key to the "on" position (not start), put the gas pedal to the floor and hold it until you hear the ACD pump turn on (it will one only for a ssecond or two). You will have to do this many times. Just remember to keep filling the reservoir while bleeding. Also remember that the fluid level will rise after you drive it around, so don't top it off after you are done bleeding it. Keep it a little bit below the max line.
Old Sep 25, 2009 | 06:49 PM
JohnDoe1984's Avatar
I thought the rope around the cross bar was a good trick.
Go in through the right wheel well.
If you have access to one of these it was awesome. It's a motorcycle jack.
I got mine in the first try.
Old Sep 26, 2009 | 08:39 AM
thedru13's Avatar
Great stuff everyone. Thanks again. My trans jack looks similar and should do the trick. Did you have to unbolt the shifter assembly to twist it to get it to fit around the mount? I had to do that to take it off wasn't sure if I would need to do the same to put it on.
Also what was the rope for? was that just to hold it?
Old Sep 26, 2009 | 08:43 AM
bevolucion's Avatar
a hoist to manipulate the engine from the top is a good idea, but with a jack like this I don't think u will have a problem. My jack was my arms so a top engine hoist help to angle the engine lower on the tranny side. Any way you put it is not easy. Best of luck
Old Sep 26, 2009 | 08:45 AM
bevolucion's Avatar
Oh and make sure u dont knock the wedge collar off with the spline like I did.
Old Sep 26, 2009 | 11:10 AM
rdtech's Avatar
great idea
Old Sep 26, 2009 | 05:06 PM
Yeah the rope just helped it from falling and held it steady when your arms get tired. The cherry picker engine hoist helped but the drawback of it is the wheels and legs of it get in the way a little under the car.
The clearance is unbelievably tight. The tall bolts that bolt to the motor mount on the driver side are hard to sneak past everything. I thought about dropping the steering rack but in the end I just barely squeaked by it.
I had my engine tilted down as low as it would go. The pully was up against the passenger fender. Like I said though.. first try.. didn't even knock my retainer clip off once.
Old Sep 26, 2009 | 07:04 PM
thedru13's Avatar
Well I messed up. I got it to a point then heard a ping.. I was like uht oh there goes the wedge collar and sure enough it was sitting in the bell housing. Is there anything i can do? Can I put it back into the pressure plate? UGH this is a royal Pain in the ***.
Old Sep 26, 2009 | 07:46 PM
newevil's Avatar
Good luck i just used 1jack to support the engine 1 to support the trans under the seam and 1 to support the back of the trans also removed the bumper to give a little more visibility\space and took my time. Make sure u find the clip that locks the ring in place should just pop in if it's not mangled too badly I'd just get a new one.
Old Sep 26, 2009 | 07:48 PM
thedru13's Avatar
i am starting to think the 6sp is different than the 5sp. I am having a hell of a time getting the shifter counter weights to clear the inner fender and motor mount. THIS SUCKS...
newevil's Avatar
Oh and you'll have to remove the p plate to get the clip
