View Poll Results: What Weight Oil Are You Using?
0W-30
23
5.67%
5W-30
81
19.95%
10W-30
174
42.86%
0W-40
2.22%
5W-40
15
3.69%
10W-40
24
5.91%
0W-50
0.99%
5W-50
10
2.46%
10W-50
0.99%
15W-50
23
5.67%
20W-50
30
7.39%
10W-60
0.99%
Other please post what it is
1.23%
Voters: 406. You may not vote on this poll
Old Oct 1, 2009 | 05:32 PM
  #46
big block ix's Avatar
^I use cold E85 and my thick 20-50w oil as a auto theft deterant (immobilizer)
Old Oct 3, 2009 | 02:00 PM
  #47
dambikeracer's Avatar
Originally Posted by apagan01
no it doesnt, the thicker the oil the more chance to starve the turbo bearings from oil you have, the oil pasages on the turbo are small therfore using a 20W50 is just looking for trouble, you dont see the effects now but soon you will by starving an engine and turbo
I see your thinking but don't the heat of the Turbo break down the viscosity??? If what you are saying is that thinner oil is better for a Turbo, then why are most engine builders running 15 or 20w-50??? Why are they not pushing 0w-20???
I had always ran 5w-30 then I switched to SSO 0w-30, then to Dominator 10-30, and now that I have the FP Red, I switched to 10w-40 and it take a while to heat up. Now, my car feels like it don't want to go, untill it is warmed up.
When I talked to a rep at Amsoil they told me to run Dominator 5w-20
Old Oct 3, 2009 | 03:49 PM
  #48
MR.CT9A's Avatar
I use the brad penn 20w50 in a buschur 2.0
Old Oct 4, 2009 | 02:11 PM
  #49
apagan01's Avatar
we are still in the 80s train of thought
where engine builders and mechanics still think that thicker is better for safety, back in the day engine oils needed to be thick because the manufacturers toleranced their engine sloppy as heck when i say sloppy i dont mean BAD i mean LOOSE, where today's mesurements range in the .002-.004 and back in the day was in some case double if no tripple that , bigger the tolerance the thicker the oil RIGHT because you dont want oil passing by the rings and you need the extra thickness to take up the slop between the crank and that bearing, the oil creates that cushion needed.
with todays engines being blueprinted with tight numbers and oils being alot better than yesterdays by only using synthetics there is no need of that thicker oil, alot of people have not caught up and it makes them feel comfortable to reccomend a thicker oil also because the clients are asking for it so ussualy they just give what the clients want affraid to loosing them.
Mark my words in about 5-10 years people will start realizing that thick oil is thing of the past,,,, thats if we still have gas engines that require oil.
iam not saying to use 0W20 or 5W20 in an Evo 8-9, although i bet you a full oil change that if you put
0W20 in your evo and road raced it and came back and drainned it and ran analysis your engine would be fine, you might loose some oil on high boost.
Old Oct 4, 2009 | 02:24 PM
  #50
STIKILLA1084's Avatar
mobile 1 10w 30 basic bolt ons
Old Oct 6, 2009 | 10:09 PM
  #51
0W-30 or 5w-20 for the winter?
Old Oct 6, 2009 | 10:17 PM
  #52
LancerEVA06's Avatar
Mobil 1 0W-30. Over 400HP/FT LBS. E85, stock turbo, Kelford 272s.
However, I cant say much on how good the oil is. I've only done 2 oil changes to date. 4900 miles :-(
Old Oct 6, 2009 | 10:18 PM
  #53
xRoguex's Avatar
mobil 10-30
every bolt on part that they make!
Old Oct 7, 2009 | 02:56 AM
  #54
MADBISH's Avatar
Royal Purple 5w-20
Old Oct 7, 2009 | 04:15 AM
  #55
apagan01's Avatar
on the Evo 8 and 9 for this cold winter comming up an 0W30 or 5W30 would suite, for any summer temps 10W30 would be fine, and if you are running high horsepower high boost and hot fuels with a built engine 10W40.
Keep in mind my reccomendations are based on Fully 100% synthetics, non of that hybride, blend junk
For EvoX mildly moded, 0W30 SSO all the way, if you want to beat on the car a little more moded 5W30, SEE BELOW
Old Oct 7, 2009 | 09:59 AM
  #56
Wicked Evo 9's Avatar
Royal Purple 10w-30
Old Oct 12, 2009 | 07:33 AM
  #57
4cdndctn's Avatar
Spring/Summer - AMSOIL Dominator 15w-50
Fall/Winter - AMSOIL Dominator 5w-20
Forget power for a moment, consider the wear or build of your motor. In my case, I have a fresh built motor and the 10w-30 I was using in the summer wasn't thick enough per my dipstick post build.
I used to use Motul 300v and it was great, heck it even smelled like bubble gum and managed to work really well. However, due to cost and availability, I decided to use what I had used in track cars prior, Amsoil, and haven't looked back. the Dominator series is impressive.
I still use stock oil filters as aftermarket brands have presented fitment issues on my MR.
Old Oct 12, 2009 | 12:58 PM
  #58
wshihdnevo's Avatar
Highly unlikely...
Old Oct 12, 2009 | 02:01 PM
  #59
SWOLN's Avatar
Originally Posted by wshihdnevo
Highly unlikely...
Actually, from a oil flow standpoint apagan01 is correct.
Old Oct 12, 2009 | 02:22 PM
  #60
wshihdnevo's Avatar
Tell that to my turbo that is absolutely perfect and been running 50w oil for 2 years...?
