compressor wheel-housing clearance
Old Sep 27, 2009 | 02:29 PM
eTiLiKo's Avatar
OEM EVO IX turbo : what is the specified value for the clearance between compressor wheel and housing? And for the turbo side?
Thanks
Old Sep 27, 2009 | 08:01 PM
sparky's Avatar
Originally Posted by eTiLiKo
OEM EVO IX turbo : what is the specified value for the clearance between compressor wheel and housing? And for the turbo side?...
If you don't mind my asking, why are you wanting to know this spec?
Old Sep 29, 2009 | 09:29 AM
eTiLiKo's Avatar
Because I want to compare the accuracy of aftermarket stock appearing turbos with the OEM unit.
Old Oct 1, 2009 | 02:50 PM
eTiLiKo's Avatar
BUMP.
FP?CBRD?Anyone have this info?
Old Oct 1, 2009 | 10:19 PM
Agent Orange's Avatar
The Evo 1-3 TD05 turbos were 0.4-0.5mm clearance on compressor side as per the FIA homologation papers, can't see that having changed much on the newer TD05s.
Old Oct 3, 2009 | 12:35 PM
eTiLiKo's Avatar
Are you sure?
This is an EVO IX FIA homologation, but I can't see any info on this tolerance
Old Oct 3, 2009 | 05:29 PM
The homologation normally states the compressor wheel inducer diameter and also the cover inlet diameter at the same point, from which clearance can be calculated.
I use 2 layers of electrical tape as a gauge in the comp side, and 3 layers on the turbine side when machining hybrids.
Old Oct 5, 2009 | 03:24 PM
eTiLiKo's Avatar
Not in the EVO IX homologation.
At what tolerance have you set your hybrid?
Old Oct 6, 2009 | 02:50 AM
I aim for around 0.5mm on the compressor side and 0.8mm on the turbine side and use layers of tape as a gauge when machining.
Works for me.
Do you have reason to worry about the clearances of an aftermarket turbo?
Old Oct 6, 2009 | 03:05 AM
eTiLiKo's Avatar
A turbine machinist here in Italy after inspected some aftermarket EVO IX turbos says that 0.5mm is way too big for that clearances, so I want to know what is the OEM admitted clearances.
Rookie05r1
Midwest Region
Aug 29, 2011 03:44 PM
moak89
20
Nov 5, 2008 12:15 AM
clip14
18
May 27, 2008 09:37 PM
Johnboy1065
22
Jul 22, 2007 05:45 PM
