Buschur MAS Pipe
Old Oct 18, 2003 | 12:18 PM
EvolutionBoy67's Avatar
Buschur MAS Pipe
this might sound newb or retarded but i just have to know. Does tha MAS pipe replace the MAF and if so would this help solve the bov problem of VTA thanxs please dont flame
Old Oct 18, 2003 | 03:01 PM
GTVEVO's Avatar
Nope , Sorry. The pipe is just bigger around to help flow more air. The MAF sensor attaches to the end of the pipe. Basically you can't get rid of the MAF unless you convert the car using a complete engine management system.
Old Oct 18, 2003 | 06:58 PM
SAEVO's Avatar
excatly what he said.....I have the MAF pipe and intake
Old Oct 18, 2003 | 10:51 PM
Hammerli's Avatar
I think that Buschur is running without the MAF sensor now that they are using the AEM EMS. I have not talked to Tym, but somewhere he posted something saying they were getting it dialed in still.
Old Oct 19, 2003 | 12:21 AM
1QWKEVO's Avatar
you will need some sort of fuel management when adding the pipe. Tests have shown that adding the pipe alone affects the airflow into the motor so much that the stock ecu can not correct itself enough to compisate for it. Some have lost 5-10hp by adding the pipe.
Old Oct 20, 2003 | 10:04 AM
David Buschur's Avatar
The MAF pipe simply replaces the stock corrugated black pipe that is between the MAF and the turbo inlet.
David Buschur
www.buschurracing.com
Old Oct 20, 2003 | 02:02 PM
loudogz's Avatar
upper ic pipe?
Is the mass air pipe needed to fit the upper ic pipe that you guys sell?
Old Oct 20, 2003 | 02:32 PM
Fireball's Avatar
There isn't a VTA problem. There is NO need for a VTA BOV, which is why there is no problem.
