Synapsis BOV Installed
Old Oct 1, 2009 | 09:38 PM
WickedWhtMR's Avatar
Talking Synapsis BOV Installed
Just installed the Synapsis BOV kit. I used the A & B ports Tee'd together to the vac source I used for my Forge RS DV. I ran C to the vac line running from the boost nipple on the j pipe to hallman ebc. Install was very easy. You've done one BOV ... you've done them all..
This might be one of the best mods I have ever made to my evo. It holds boost like crazy. No leaks... No flutter.... No bucking....
I can say with a straight face that this valve actually works better than stock. It behaves like a IX diverter valve in the city..but when you get into boost.. it just holds... This has to be the best BOV Ive ever driven with.
FYI... I have had HKS SSQV... Forge RS.... Tial.... IX diverter.... Viii diverter.
Old Oct 1, 2009 | 09:57 PM
evowario's Avatar
sweet just ordered mine cant wait to see how it performs with the fp red.....
Old Oct 1, 2009 | 10:09 PM
poordude's Avatar
Im using the forge rs, just wondering why you switched bov?
Old Oct 2, 2009 | 12:46 AM
Fast_Freddie's Avatar
Veteran: Navy
Most likely because of the part throttle bucking/flutter...
Old Oct 2, 2009 | 12:54 AM
Blackened Sky's Avatar
hmmm better than Tial?
Old Oct 2, 2009 | 03:34 AM
Evo8Emperor's Avatar
I use the synapsis at 30 psi on the stock turbo with zero complaints from day one over a year ago now I bought it.
Old Oct 2, 2009 | 03:52 AM
Veteran: Navy
The Tial is VTA so it causes idle, and lift off issues on some cars...
Old Oct 2, 2009 | 05:03 AM
danko's Avatar
nice, i picked up one of these myself. just for the record though, the name is synapse.
Old Oct 2, 2009 | 09:52 AM
I switched from the Forge because of the part throttle flutter and bucking. The synapsis is very smooth and very quick to respond. The car feels stock except for the fact the synapsis holds like a race unit.
Old Oct 2, 2009 | 01:11 PM
97TSiAWD's Avatar
This.
I also have the Synapse BOV and like it so far. Install in the stock location is a tight fit, but it works really well and solved my leaky stock BOV issues.
Old Oct 2, 2009 | 01:27 PM
overdrive1's Avatar
what boost are you running ?
Old Oct 2, 2009 | 01:39 PM
24 lbs without meth... 35 with meth
Old Oct 2, 2009 | 01:42 PM
tweakdsm's Avatar
Sounds like you went thru quite few of them....
Old Oct 2, 2009 | 01:54 PM
evofool's Avatar
i'm going to have to try that, i hate the flutter with the forge unit i have
Old Oct 2, 2009 | 03:27 PM
Ted B's Avatar
Ditto that.
