Boost Leak Test Problem
Old Oct 4, 2009 | 11:24 PM
TTP Engineering's Avatar
Just turn the engine over by hand until the valves close.
Old Oct 4, 2009 | 11:27 PM
Evokid03's Avatar
^^ and we know when the valve closes how?
TDC?
Old Oct 5, 2009 | 08:00 AM
When the leak stops and the pressure builds.
Old Oct 5, 2009 | 09:20 AM
Evokid03's Avatar
O I get u hahah sorry
Ima do it today n ill post results
Old Oct 6, 2009 | 09:27 AM
blackdemon's Avatar
bump
Old Oct 24, 2009 | 07:04 PM
blackdemon's Avatar
Dan did a compression test on my car today. The motor was not hot but was still warm. These were the results cylinder # 1: 125 # 2: 125 #3 130 #4 130. Not sure what to make of this. Is this good? Should the motor be fairly hot?
Old Oct 24, 2009 | 09:42 PM
Your throttle needs to be down 100% when conducting the test.
Results should be about 180 across all 4 on a perfect engine.
Leakdown test tells more information.
Old Oct 24, 2009 | 10:05 PM
ronitlancer's Avatar
I don't know what EGR is but, I tried to do my own boost-leak test last week and I read 0psi no matter how much air I put into the turbo. But I had a boost-leak test done about 3 weeks ago at a shop and it read boost up to 30psi. I have since changed my BOV and hookup arrangement with a custom built area so I needed to test that area for leaks but I couldnt get my car to read any pressurized air. None at all. My compressor was apparently sending out 30psi for about 45 seconds straight, my boost gauge in the car never moved at all and I didnt even hear my turbo spinning. I think it was my compressor??
Old Oct 25, 2009 | 05:26 AM
blackdemon's Avatar
I was told that you are not looking for a exact number when doing a compression test but consistency.
Old Oct 25, 2009 | 06:38 AM
Ted B's Avatar
The leak should be easy to find with the air running and you under the hood.
That is correct, as items like larger cams tend to reduce the static compression test numbers significantly. When this happens, it does so across ALL cylinders, so consistency is the only reliable indicator.
Old Oct 25, 2009 | 09:07 AM
gsrboi80's Avatar
Wired issue Leo. I'm guessing there is a line off somewhere for sure. I have neveer put my car at TDC when boost leak testing it and have always been able to put air into the system without issue.
Tripple check all lines something is off
Old Oct 25, 2009 | 12:10 PM
Ted,
Do you mean simply when the car is running? Or did you mean if I correctly sent pressurized air through the system with a boost-leak test it would be easy?
Old Oct 25, 2009 | 12:13 PM
Ted B's Avatar
I mean you pipe in air, let it leak, and use your ears, and possible a spray bottle with soapy water to find where the air is escaping.
Old Oct 25, 2009 | 01:48 PM
GST Motorsports's Avatar
Looks ok for a 9.
Evo 8 has higher comp test #'s, around 160-180
Evo 9 is quite a bit lower, 130-150
It's not just "180" for all like somebody previously stated.
Also consistancy between cylinders is the big thing to look for.
- Bryan
Old Oct 25, 2009 | 02:16 PM
Compression numbers will have several factors including aforementioned effect of cams, pistons, if the head has been cut, what headgasket is being used and so on.
Our race built and OEM rebuilt engines typically are 180 across the board.
