Boost Leak Test Problem
Old Aug 26, 2010 | 10:36 PM
  #76
TommiM's Avatar
Originally Posted by RSMike
with these leak tests, if you pressurise to 20psi or whatever, is it supposed to hold flat?
I can get mine to that pressure and then it'll bleed off at about 1psi every 2 seconds... is that normal?
Ya Im curious about that as well.
Old Aug 26, 2010 | 10:48 PM
  #77
Ted B's Avatar
If you shut off the compressed air source, the pressure will bleed in a matter of seconds. This is normal. You conduct the test while holding the pressure steady and checking for leaks.
tboboy
10
Sep 2, 2008 08:34 AM
BCOZEVO
Aug 10, 2008 10:10 AM
PorkRoll
23
Oct 18, 2007 01:33 PM
vennom
13
Sep 28, 2006 03:09 PM
scottatyamaha
Aug 23, 2006 05:10 AM
