Boost Leak Test Problem
Old Oct 25, 2009 | 03:10 PM
  #31
Chris Moore's Avatar
Originally Posted by TTP Engineering
Compression numbers will have several factors including aforementioned effect of cams, pistons, if the head has been cut, what headgasket is being used and so on.
Our race built and OEM rebuilt engines typically are 180 across the board.
Most 9's I see are 140 across the board. Including low mileage stock cars.
Old Oct 25, 2009 | 06:24 PM
  #32
blackdemon's Avatar
Originally Posted by gsrboi80
Wired issue Leo. I'm guessing there is a line off somewhere for sure. I have neveer put my car at TDC when boost leak testing it and have always been able to put air into the system without issue.
Tripple check all lines something is off
I'll do that luke. Thank you
Old Oct 25, 2009 | 06:44 PM
  #33
dxbtune's Avatar
From: I'm Canadian living and working in Dubai/Kuwait/Bahrain
Originally Posted by GST Motorsports
Evo 9 is quite a bit lower, 130-150
It's not just "180" for all like somebody previously stated.
Also consistancy between cylinders is the big thing to look for.
- Bryan
man, crapped myself when i read 180.
i'm 140 139 140 139 evo IX
Old Oct 25, 2009 | 08:20 PM
  #34
EvoDan2004's Avatar
Your throttle needs to be down 100% when conducting the test.
Results should be about 180 across all 4 on a perfect engine.
Leakdown test tells more information.
aaaaa no. and the TB was 100% open.
odd. me too. but his car just would not take any pressure.
Looks ok for a 9.
Evo 8 has higher comp test #'s, around 160-180
- Bryan
which is what i been saying.
Old Oct 25, 2009 | 08:23 PM
  #35
GST Motorsports's Avatar
Indeed, real world experience always better you know. Anybody can post the service manual.
-Bryan
Old Oct 26, 2009 | 12:35 AM
  #36
haseeb's Avatar
shud it be the same if i have 2.3l stroker with 86 mm
thanx
Old Oct 26, 2009 | 01:11 AM
  #37
Fast_Freddie's Avatar
Veteran: Navy
FYI if you guys are having problems with boost leak tests with the synapse you need to take the vaccum lines off the BOV so it closes, as at idle the BOV is open...
Old Oct 26, 2009 | 02:08 AM
  #38
ronitlancer's Avatar
how did this go from a boost leak to a compression test thread.
Old Oct 26, 2009 | 02:50 AM
  #39
yahu's Avatar
^easy - it got posted on EvoM!
Old Oct 26, 2009 | 11:18 AM
  #40
haseeb's Avatar
Ny 1 willing to answer my simple question ?
Old Oct 26, 2009 | 04:31 PM
  #41
blackdemon's Avatar
its still that. we just doing further testing. Now that the comp test came back possitive we will continue to do a leak down test. If that comes out good we will then continue with the boost leak test.
Old Oct 27, 2009 | 10:41 AM
  #42
Evokid03's Avatar
hey guys i figurd my issue with not holing pressure.
I put the car at tdc n had someone turn the crank slowly as i push air into the system..
eventually about 1/4 away from tdc it held
Old Oct 27, 2009 | 10:45 AM
  #43
gsrboi80's Avatar
Maybe I've gotten lucky the 100+ times I shut off my car prior to doing a boost leak test. Again I have never had to put the car at TDC or turn the crank ever at all for that matter. Since 05 I've don 100+ of boost leak test on my car and my ex's RS
Old Oct 27, 2009 | 12:18 PM
  #44
LV///R's Avatar
See, that's what I don't get. I had air coming straight out my exhaust like I mentioned previously. We tried cranking the engine over a couple times and every time we boost leak tested, we had the same issue with the pressure coming out the exhaust.
And you are right, there's absolutely no way of getting lucky 100+ times in doing it, so there has to be some sort of issue with the OP's and my cars....
There's got to be an explanation for this...
Old Oct 27, 2009 | 04:01 PM
  #45
gsrboi80's Avatar
Pretty much standard practice on my evo at every oil change. Maf cleaning and a boost leak test. I know Dan's boost leak tested his car more times then he can count. Especially with all the changes hes done to his set up over the years and as he mentioned he never had to put the car to TDC or adjust the crank
