One step colder for my 9 with red not sure which to get ?
Old Oct 5, 2009 | 03:15 PM
mantosride's Avatar
Okay So i am more or less a newbie, I know i need a step colder plug with my current set up, running 93 and 27 psi on my red, the car is an 06 MR any recommendations as far as plugs go, any help is much appreciated. please no flaming i have searched, and just come up with a bunch of threads that are more or less filled with garbage, that might as well be french to me, and i failed french in school !
Old Oct 5, 2009 | 03:16 PM
xspsi4's Avatar
I run ngk bpr7es with 29 psi.
CMB's Avatar
CMB
Bpr7es
Old Oct 5, 2009 | 03:18 PM
cij911's Avatar
I am pretty sure with the 9 you don't have options - just use the factory...
Old Oct 5, 2009 | 03:20 PM
97TSiAWD's Avatar
Non-"garbage" thread:
https://www.evolutionm.net/forums/ev...ead-plugs.html
Old Oct 5, 2009 | 07:28 PM
mantosride's Avatar
so when you say " none " i am kind of confused because the link that you have included has plenty of people with 9's changing plugs can you explain ?
Old Oct 5, 2009 | 07:32 PM
recompile's Avatar
Stock IX iridiums are good to 600+ whp, just need to gap them tighter if you are running high boost. They are GREAT plugs and there's no reason to use anything else.
https://www.evolutionm.net/forums/ev...on-650whp.html
Originally Posted by Early EVO
I made 661 on a mustang dyno with a IX on the stock plugs. Was using AEM with BR COP. IX plugs were stock untouched gap. Never went over 37 psi on C16.
Originally Posted by JohnBradley
Stock VIII/IX heat range iridiums will hold up to 960+whp when gapped down.
Old Oct 5, 2009 | 07:34 PM
SLOW2.0's Avatar
if you're blowing out spark you can close the plug gap some, if you need colder plugs you could switch to an 8 or 9
Old Oct 5, 2009 | 09:06 PM
97TSiAWD's Avatar
I wasn't saying "none." I just said that the thread I linked to was a non-garbage thread; there was a lot of good information in it.
Personally, I am running the Denso IKH24 plugs. Of course, this was before I read about people's recommendation to stick with the stock heat range, especially with E-85.
Recent E-85 spark plug thread:
https://www.evolutionm.net/forums/ev...plugs-e85.html
Old Oct 5, 2009 | 09:14 PM
fugiwara's Avatar
bpr7es are for the MIVEC motor people, if you wanna give suggestion please see what evo "mantosride" drives.
kyoo
Jun 25, 2016 12:10 PM
Ralli_Red
Mar 28, 2016 07:03 AM
Done
210
Apr 4, 2015 10:47 PM
smokedmustang
10
Jun 5, 2005 09:04 AM
