Re-Torque Head Studs?
Old Oct 6, 2009 | 12:23 PM
kmcconn9's Avatar
I have had my ARP head studs installed for about 40,000 miles now. I have a slight head gasket leak on the backside of the motor.
The head studs were installed by the 1x1 method (not me).
Should I attempt to re-torque them before I pull the head and install and new gasket and studs?
If so, I assume I would loosen and re-torque in the order you would to torque down the new studs correct? I would have to do this by the 1x1 method as well I would assume.
Thanks.
Old Oct 6, 2009 | 12:28 PM
justa4banger's Avatar
If your headgasket is already leaking than theirs no way around it...pull the head and get it milled and new head gasket..... i
Old Oct 6, 2009 | 12:31 PM
05blue8's Avatar
Ditto to justa, first I would tell the person that did it thanks for the headache, then replace the headgasket and have the headwork done
Old Oct 6, 2009 | 12:43 PM
kmcconn9's Avatar
Thanks Pruven Performance....
Old Oct 6, 2009 | 12:45 PM
kmcconn9's Avatar
I was told that you wouldnt have to get it milled, dependng on howbad the current leak is. If it is only slight, and not mixing with coolant, then the head shouldnt be warped enough to warrent a mill job.
Old Oct 6, 2009 | 12:55 PM
kmcconn9's Avatar
Also, I assume I should replace the arp head studs as well since they have been on for so long. Daily boost around 30 lbs...
Also, if you are not getting the head milled, then would have need to remove the intake manifold and tb from the head?
Old Oct 6, 2009 | 01:32 PM
EVO8emUp's Avatar
Why in the world would people suggest getting the head milled?
Esp w/o even confirming that it needs milled.
If you're taking the head off, you can take it somewhere to have it checked.
Clean the head with a razor and Scotchbrite. If you have it cleaned up real nice, some places will check it for free.
Old Oct 6, 2009 | 01:48 PM
97TSiAWD's Avatar
Most people (including me) recommend replacing the head studs especially after 40K miles and since it is pretty cheap insurance. I know many people/places re-use them, but, unless they are the L19 studs, I would just replace them.
Old Oct 8, 2009 | 04:17 AM
Sharkbite2000's Avatar
Can't belive people still go over there if you want your evo running messed up that's the perfect place for you Pruven Performance
Old Oct 8, 2009 | 06:38 AM
batty200's Avatar
I have never had any reason to retorque head studs unless they werent torqued properly the first time when using an MLS HG. Some say with a composite gasket it compresses after it heatcycles or something along those lines. I dont buy it. I have also done the 1x1 head stud install a bunch of times with ZERO issues if you do it right. The only time a retorque is in order 100% is on a MKIII Supra where the factory torque setting is tooo low and retorquing the bolts to 72lbs vs the stock 55 will save you the HG problem known on the 7M-GTE motor.
SDevol8
26
Mar 27, 2017 04:09 PM
Evo-IXse06
32
Aug 13, 2016 09:55 PM
Farga
Pacific Northwest
Mar 20, 2012 06:46 PM
jid2
23
Oct 3, 2009 05:38 PM
Tuner@Swift
Aug 6, 2008 05:38 PM
