Best Turbo for 600hp
Old Oct 12, 2009 | 01:19 PM
3gEclipseTurbo's Avatar
Ok so gonna be doing a complete motor build this winter, on my quest for 600whp. i have a 4g64 block. Im trying to stay under $1000 if possible but not much over. So far im thinking PTE SCM61 56 Trim ~ Stage 5 Turbine Wheel
Specs:
Compressor Wheel Diameter – 61mm
Compressor Wheel Inducer - 2.416"
Compressor Wheel Exducer – 3.227"
Compressor Wheel Trim – 56
Compressor Cover Inlet Size – 3”
Compressor Cover Outlet Size – 2”
Bearing System – PTE Race 360
Turbine Housing A/R Ratio - .63
Turbine Wheel Style - T35 (Stage V)
Turbine wheel Inducer – 2.795"
Turbine wheel Exducer – 2.437"
Turbine Wheel Trim - 76
what do you think? i will be doing 8.3:1 pistons, 280cams, 3" turbo back 1200cc injectors with meth injection tuning on 93 pump 25-30psi
Old Oct 12, 2009 | 01:20 PM
SBR INC's Avatar
man, there are tons of options! Probably go with a PTE 6262 or something along those lines. It will be able to make that kind of power on pump with proper support and tuning.
Old Oct 12, 2009 | 03:31 PM
any other opions?
Old Oct 12, 2009 | 03:57 PM
Steve93Talon's Avatar
If you're on a budget and want to go T3, you can't beat a Borg Warner non-extended tip S362. it'll make 600whp and spool pretty well for it's size. A few local DSMers have put their cars in the 10s on pump/meth with it.
Old Oct 12, 2009 | 06:45 PM
JohnBradley's Avatar
61mm is a kind of old design. There are definitely a few others that I would use before that. Any of the HTA 35Rs, the 6262, the FS635, 6562, etc.
Old Oct 12, 2009 | 06:46 PM
ScorpionT's Avatar
A 6262 journal bearing would be the way to go. You can pick them up for $1k pretty easily. The Borg Warner are pretty good, but they went up in price most places and are over $1k.
Old Oct 12, 2009 | 07:42 PM
ya im thinking about the 6262 i can get it for $850
Old Oct 12, 2009 | 07:43 PM
im not to worried about spooling as i have a 2.4L
Old Oct 12, 2009 | 08:35 PM
mandy1's Avatar
will go with 62/65 instead journal bearing.
Old Oct 12, 2009 | 11:35 PM
so im trying to descide between the 6262, 6265, but then for a little extra and still in my budget theres the 6765 which can support 755hp, so if down the road i want more hp i wouldnt have to get a differnt turbo.
Old Oct 30, 2009 | 03:12 PM
mandy1's Avatar
67/65,i believe Mike Awd is on 920 hp at 44psi
Old Oct 30, 2009 | 07:59 PM
grim~'s Avatar
pt 5857
Old Oct 30, 2009 | 09:35 PM
1NastyMR's Avatar
6262 non BB for 850$ and BB for 1299$ I believe best choice in your budget
Old Nov 9, 2009 | 02:34 PM
midnightkiller3's Avatar
what turbo did u end up using?
Old Nov 9, 2009 | 02:38 PM
evoracingstar's Avatar
i <3 my hta 35r 511 pump gas stock motor stock ecu but going to build it this winter. deff should be right or over 600 pump!
