Buschur Ported exhaust manifold, how much was YOURS ported?
Old Oct 12, 2009 | 11:21 PM
Sideck's Avatar
my ex- exhaust manifold... now i have new setup....
ported more than 1mm, colector gasket matched and the runners are fully ported....
you going to get very good power with the br manifold...
i got 350 whps 23psi, with my manifold, evo 8 turbo ported, turbo back exhaust and keldford cams...., stock intake, stock tb.... 91 octanes...
Old Oct 12, 2009 | 11:38 PM
Evo_IX_Guy's Avatar
Im looking into getting a BR ported manifold, not really sure if I would have to take mine off and send it in or can I just buy one ported and polished? Also no one is posting up prices on how much they paid.
Q8_EVO's Avatar
Originally Posted by 97TSiAWD
This thread is about exhaust manifolds.
guy wanted to see how much porting is done, you can easily compare the quality of porting being done, doesnt matter if its an IM or EM.. thanks for playing along
Old Oct 13, 2009 | 04:01 AM
Liqquid's Avatar
Not trying to jump on any bandwagons_ in fact I'm running a stock ex. mani unported myself, but the Buschur piece has more than likely been tested back to back on the dyno when they were deciding how much to port... if there was more power to be gained when its all said and done they would probably have ported more and charged a little bit more since they usually like to prove everything on the dyno before using it.
With that said, one always wonders if the HTA 73, the Red's and other larger bolt on's could benefit from more porting since they have a larger exhaust wheel...
Old Oct 13, 2009 | 07:44 AM
RockmanX's Avatar
all you have to do is visit mike or br site here you go
http://www.awdmotorsports.com/burapoexma.html
Old Oct 13, 2009 | 07:51 AM
IDRINKV8'S's Avatar
Originally Posted by Q8_EVO
since i have my photo bucket open, heres some pics of the BR
weak looking i like ppi's porting better buschur
Old Oct 13, 2009 | 08:00 AM
TheDream's Avatar
You can't beat the quality that MAP produces...
Thanks for the link Rogue
Old Oct 13, 2009 | 08:40 AM
neonglh's Avatar
Just as Mike said, it's not about the size, it's about the smoothing of the problem areas. There are ridges that you port down to smooth radius, and then gasket match the outlet to the exhaust manifold. You can open up the runners more, but it's not worth it. We spent maybe an hour doing my manifold, and it's working absolutely great.
Old Oct 13, 2009 | 09:05 AM
David Buschur's Avatar
Oh boy...........some of you guys are clueless.
The ported/coated manifold from us is $195 with your core.
Next, porting the exhaust manifold to match the gasket at the head is a HUGE HUGE HUGE mistake, stupid mistake. It does not work and ruins the manifold. The head is NOT as big as the gasket either, hold the gasket up there and look at it. Back in the early 1990's the gasket that was used on the manifolds was the shape of the exhaust port. We use that style gasket to port the head and to port the inlet to the exhaust manifold because that gasket is very close to the actual port size/shape. By porting the manifold inlet to that size it is very closely matched (slightly larger than) the stock exhaust port on the EVO head.
The other end at the turbo is also gasket matched to your gasket and turbine housing.
The other pictures/links all look pretty, great for selling parts but after the initial 2-3" of runner is done and matched to the head there is NO gain from doing the rest. The collector is also smoothed into the runner and rounded off and that is where the rest of the gains come from.
9.5's at 145 mph on our ported manifold. You can polish a turd and make it look good, backing up your claims with actual ET and MPH results isn't something that can be faked.
Old Oct 13, 2009 | 09:12 AM
IDRINKV8'S's Avatar
my friend had the ported exhaust manifold,and ported intake manifold and it looked like it was just cleaned up really well sorry but map performance does some serious porting work,and ppi as well just speaking the truth...those two parts didnt impress me at all....jmo.
Old Oct 13, 2009 | 09:15 AM
neonglh's Avatar
+1
Studderin had this conversation here before he was banned from the site. People kept saying that you needed to polish the whole thing, which is not correct. Sales pitches can only go so far, results speak for themselves.
Old Oct 13, 2009 | 09:44 AM
idrinkv8's, well I say sorry to you too because there is more to a part than how pretty you attemp to make it look. Look at the records and the testing. Do these other companies you are comparing the work to have dyno's and dyno sheets to prove what works and what doesn't? How about the track records to also back up the parts? The answer is no.
We've gone to the trouble of flow benching the parts to look for flow even and have done it with the parts bolted to a cylinder head on the bench (which is the only way to check those parts).
Our results speak for themselves. Check my signature.
Old Oct 13, 2009 | 11:59 AM
BoostINurI's Avatar
^^++1000000000
Old Oct 13, 2009 | 12:11 PM
ladysman's Avatar
David,
How do the coatings hold up? That is one thing i'm most interested in. I would want the black coating of course. I'm one (like i'm sure many others) to do something once so i don't want to have to take it off then get it recoated and stuff. I have seen this on a few different coatings when I was in the honda world. I'm assuming you would guarantee it not to flake/peel/falloff, etc.
I ask because a ported/coated manifold is on my xmas list.
Old Oct 13, 2009 | 12:24 PM
Kracka's Avatar
The coating Buschur uses on his ported exhaust manifolds is excellent. Mine is almost 2 years old and it still looks very good. Its no longer as glossy, but there is no flaking or chipping what so ever after 30k of daily-driven street miles including salty Minnesota winters and plenty of touchless car washes.
David - Thanks for the above info.
