Converting to E85?
Old Oct 13, 2009 | 02:26 PM
grizly3610's Avatar
Converting to E85?
I was thinking about switching to E85 but have a few questions. What all would i need to change over i already have a walboro 255 and RC750 injectors. would they be fine or would i need larger injectors? Also would a stand alone be needed or could i get by without one?
Old Oct 13, 2009 | 02:34 PM
Dragking2189's Avatar
I switched to e85 a while ago and I love it , you'll need at least 1200cc injectors if your running a stock turbo/fp green/fp red if you go with a bigger framed turbo like a 35r ect ....you'll need 1600cc injectors , bigger fuel rail , and two walbro's inside the tank (buschur double pumper or full blown both are good) that's basically it , you can go with bigger lines for more volume but you don't really need them.
Old Oct 13, 2009 | 02:41 PM
NickieBlaine's Avatar
if your staying stock 9 turbo, i think 1000's would be alright, with a single pump. But if your going to be running a bigger turbo, or looking for more than mid 400's you might want to look at 1250's or slightly larger and the double pumper mentioned above.
it all depends on your mods, boost, and future plans.
Old Oct 13, 2009 | 02:47 PM
ch53avitech's Avatar
This has been covered numerous times. A quick search will yield you the results your looking for.
Old Oct 13, 2009 | 03:57 PM
97TSiAWD's Avatar
Lots of general information to get you started:
https://www.evolutionm.net/forums/al...ints-tips.html
The Alternative Fuel sub-forum with lots of E-85 related topics:
https://www.evolutionm.net/forums/alternative-fuel-225/
Old Oct 13, 2009 | 05:17 PM
grizly3610's Avatar
I would like to have 500 at the wheels thats my goal. So a standalone is not needed? I talked to a shop about tuning it and they were talking like i would need a standalone to tune weather or not i converted to Corn Juice. Sorry for all these questions im a new-B
Old Oct 13, 2009 | 05:20 PM
dmoevo's Avatar
honestly i dont think you will need a standalone, plenty of people making 500+ on stock ecu, especially with SD and the advancements in ECUFlash unless you decide to do some crazy Hp youll be fine.
Old Oct 13, 2009 | 06:57 PM
grizly3610's Avatar
Sweet thats good to know. So basicly all i really need is bigger injectors and another fuelpump? what would be the best injectors and best fuelpump? Can i just get another walboro 255 cuz i already have one? Or would i need to get a diff one?
Old Oct 13, 2009 | 07:22 PM
JohnBradley's Avatar
For your 30R on E85 and 500+whp you'll need a second pump and more like 1450s. The FIC1450 fits the bill nicely. A stock ECU can be used to make as much power as you'll ever need/want whether you use the stock MAF or go to speed density on the stock computer.
If you were on a IX turbo (thought I saw that mentioned) you will max 1000s and one pump around 460whp. I have made 475-480 at 83% IDC with 1200s and one 255 so thats almost all the way there.
Old Oct 13, 2009 | 07:52 PM
grizly3610's Avatar
Sounds Great one more question, Can I just get another walboro 255 and hook it up to the other one? if so how would I do this? No fuel lines would be needed or anything?
Old Oct 13, 2009 | 07:54 PM
Buschur racing double pumper is a good way to go.
Old Oct 13, 2009 | 07:56 PM
McLaren F1 2003's Avatar
youll need something like this:
https://secure.buschurracing.com/cat...a2a4c39500d07f
Old Oct 13, 2009 | 08:14 PM
grizly3610's Avatar
So a Double Pumper and FIC1450 injectors Plus a ECU Flash and ill be set?
Brandonliburdi
Oct 2, 2016 10:48 PM
abosoxfan4life
Nov 17, 2015 06:15 PM
Mr. Castle
E85 / Ethanol
12
Oct 13, 2015 06:46 AM
LANEVOLIU
E85 / Ethanol
May 27, 2013 11:39 AM
aronjaskim
26
Aug 20, 2010 07:08 AM
