Cam install costs
Old Oct 16, 2009 | 02:01 PM
  #31
Thomasevo's Avatar
ethan spend 15 dollars on a timing belt tension tool or just zipstrip the belt to the cam gears and swap the cams out your self. You would need some very common tools like a socket set (metric) and pop the valve cover off take off the cam holder plates off and put your new cams in then torque the plates back down to specs and reverse the disassembly whalah. This article should get you started
http://www.evomoto.com/tech_articles..._article_id=18
Old Oct 16, 2009 | 02:16 PM
  #32
cij911's Avatar
Originally Posted by X_Evo
I would replace the headstuds. Cheap insurance. There are a lot of tuners that will not even tune your car with that kind of turbo and the lack of headstuds. They are only ~$100. Would be silly not to do it.
????? Awful advice in my book....
Old Oct 16, 2009 | 02:58 PM
  #33
awd2gen's Avatar
850 is a nice chunk of change but is prob avg for quality work at your more known shops.
Old Oct 16, 2009 | 03:06 PM
  #34
KevinD's Avatar
Originally Posted by igo4bmx
just curious how a 1-3% card rate plus interchange can be a huge percentage?
1-3+% on internet transactions and 50 dollars a month and now i have 1000+ in rent , plus webpage fees, internet at the shop, phone bills, electricity... you get the point. working out of my garage was easy, and i could charge barely anything.
rockmanX and sgt petty, you both have quotes already and i'll honor both the prices i gave you
Taimur: i have stock headstuds on my car, 500+whp, 32psi on a 35r for 30k miles and still going strong. motor has 86k miles and still going strong.
Old Oct 16, 2009 | 03:55 PM
  #35
Taimur's Avatar
Thanks for this info. Appreciate it
Old Oct 17, 2009 | 11:31 PM
  #36
dsmloverforlife's Avatar
If you look in the how to do forums they have steps in there on some short cuts. But the way I was taught in school is to take the head off.
tscompusa
Oct 29, 2016 03:50 AM
ethan169
13
Jan 12, 2014 06:20 PM
ethan169
Aug 24, 2011 03:38 PM
ethan169
Aug 11, 2011 05:09 AM
ethan169
Northeast Region
Jun 16, 2009 01:56 PM
