crank angle sensor quick help plz
Old Oct 20, 2009 | 08:34 PM
sleeper04's Avatar
i currently have everything tore apart but can seem to get the actual sensor out it seems that timing belt is in the way ?? any suggestions
Old Oct 20, 2009 | 09:09 PM
sleeper04's Avatar
anybody is there a trick to this?
Old Oct 20, 2009 | 10:01 PM
Bobster22388's Avatar
This should really be in the How-to section BTW, but either way I found another thread that might help you.
https://www.evolutionm.net/forums/ev...le-sensor.html
Knightracer posted up everything you should need to know to replace the sensor, If you need the manual PM me
Try searching a little bit to
Old Oct 21, 2009 | 04:03 PM
sleeper04's Avatar
i read that and it mentioned nothing about removeing the timing belt?
Old Oct 21, 2009 | 04:11 PM
RoadSpike's Avatar
You can get the sensor under the belt but its a pain, i did it. If you need to use the tensioner tool to loosen the belt some but if you do that make sure you zip tie your belt to the crank and two cam sprockets.
supak1111
Jan 21, 2017 12:47 AM
asu11
Oct 9, 2016 05:43 AM
CtSilver03Evo
Dec 15, 2014 04:01 PM
bigric09
Jul 13, 2007 08:18 PM
hypo74
Lancer Engine Tech
17
Jan 21, 2007 01:54 AM
