Transmission leak
Old Oct 22, 2009 | 04:11 PM
grim~'s Avatar
Transmission leak
Hey guys for a while ive noticed a small leak on my transmission so yesterday i found out where it was leaking from,attempted to fix it and changed my tranny fluid with amsoil.Well today i was hoping to see the leak fixed but its still leaking but not as much as before.Do any of yall happen to know exactly why its leaking and what i need to do to fix it?i circled the spot in this picture i found on the net.
Old Oct 22, 2009 | 04:42 PM
MitsuJDM's Avatar
The seam where the case is bolted together? Chances are the trans has been apart before, whoever put it back together may have not used enough sealer. It's not a a huge deal. That doesn't mean who ever worked on it doesn't know what they were doing. Check the bolts to may sure they're tigher and maybe try to spread some gasket sealer long the seam. It's worth a shot.
Old Oct 22, 2009 | 04:54 PM
grim~'s Avatar
its along where the seam.I put some permatex form a gasket on it last night.i guess i can just keep putting layers on it untill i can get a real fix for it.
Old Oct 22, 2009 | 05:35 PM
MitsuJDM's Avatar
The only real fix would be to pull the cases apart and re-apply the seal. It's possible you could stop the leak by doing exactly what you're already doing, but it's not a guarantee.
Old Jul 2, 2018 | 08:29 PM
Evo7Life's Avatar
Im leaking transmission fluid from the black plate any one have the gasket number so i can replace it ??
Old Jul 2, 2018 | 08:55 PM
tauro91's Avatar
U can re use it unless broken, get old gasket off and just use threebond..
Old Jul 2, 2018 | 09:09 PM
Evo7Life's Avatar
Thanks A lot
Old Jul 3, 2018 | 05:36 PM
hutch959's Avatar
unless its pouring out... i would just let it leak.. top it off once and awhile.
i know that sucks, but i wouldnt pull the tranny out just to fix the seal.
be my luck to pull it out, fix it... and then 6 months later something go out in the tranny and id be pulling it again.
Dooh.
Old Jul 5, 2018 | 01:39 PM
barneyb's Avatar
Remove and reseal with RTV.
Old Jul 5, 2018 | 02:32 PM
Pal215's Avatar
Agreed ^
Strange. Usually leaks occur in that area under the car when someone forgets to reinstall the small Tcase o-ring. Have you had the clutch changed recently? One would think that if someone is smart enough to take the trans apart, that they would at least know how to properly clean and prep a surface for RTV.
eddy5201314
Apr 21, 2017 06:34 PM
gsteensland
10
Jul 7, 2016 08:23 PM
Jordannike
Lancer Tranny/Drivetrain Tech
Jan 6, 2016 09:16 AM
yahh
Apr 11, 2012 10:13 AM
levo2nr
12
May 25, 2006 05:49 AM
