Some Clutch issues?
Old Oct 22, 2009 | 09:43 PM
eXtreme-Speed's Avatar
Some Clutch issues?
Okay, so i recently got an Exedy Twin Disk HD put in. I'm only about 350 miles into the clutch. So everything was good until this "cricket like noise" appeared at idle.... It is starting to annoy me and it only goes away when i start driving.. I search around and found that other had the same problem, but no one found a true answer. Just wondering if it's normal break in sound or something.
Another sound that pops up is when I down shift I can here the clutch grab when I let of the clutch peddle because it makes a wierd squeek like rubbing noise.. Is this normal to or not? Thanks for the help guys!
Old Oct 22, 2009 | 09:56 PM
Sievers's Avatar
When you push in the clutch does the noise go away? If so, you may have a bad throwout bearing....
Old Oct 22, 2009 | 10:05 PM
Nope, You can still here the noise strong as anything.. Thanks for the thought though.
Old Oct 23, 2009 | 08:35 AM
Bump Anyone else?
Old Oct 23, 2009 | 12:39 PM
Figured out the problem... It's time to replace all the belts lol.
anthonyrb98
19
Sep 5, 2019 05:14 PM
eddy5201314
Jan 8, 2017 10:12 PM
Fcb_boss_10
Nov 29, 2015 09:54 AM
Trunkz3
Sep 2, 2012 08:57 PM
hillbilly8R
Aug 24, 2008 12:45 AM
