Stock Motor FP Red Thread
Old Oct 28, 2009 | 10:56 PM
  #76
xRoguex's Avatar
Hell the red is fun on 20 psi on pump. I had a spark issue that caused me to run a max of 20 psi for the first few weeks after installing the new red.
The ignition problem has been solved. I cant wait to see what she will do at 27-28 psi on 93 only.
Just need to get home from this military contract - and get the car back from shep!
Old Oct 28, 2009 | 11:19 PM
  #77
sparky's Avatar
No way that you are still on the stock injectors and fuel pump, dude. So, update your modlist.
Old Oct 28, 2009 | 11:26 PM
  #78
xRoguex's Avatar
Me?
Old Oct 28, 2009 | 11:28 PM
  #79
drb's Avatar
drb
Originally Posted by RyuEvoIX
That sounds good in theory, but all cars are different. I have seen cars on TTP's dyno produce nearly the same numbers as I have and not trap as high. Until trap speeds are produced from the vehicle in question, unfortunately all it is, is speculation and theory.
A list of variables at the track that are not taken into account on a dyno:
1. vehicle weight with driver
2. rotational weight IE: tire weight, rim weight
3. tire size
4. gearing
5. wing speed/direction
6. weather IE: temperature/humidity
7. alignment
8 elevation
9. drag/downforce
10. shift points
11. shifting speed lift shifting vs no lift shifting
These are just a few variables off the top of my head. Quite a few more as well. I'm not trying to knock you, I'm just simply saying that there are FAR too many variables beyond "I am making the same power as car X" That is a mute point and can only be speculation until your car is actually on the track and proven with a slip to back up the theory. That's all.
No offense but I'm not sure that I understand your logic. Aren't the reasons that you listed the reasons that a 1/4 mile time isn't the best indicator of how much power a car is making? As you pointed out there are alot of factors other than hp that determine your 1/4 mile time.
Dan (drb)
Old Oct 28, 2009 | 11:32 PM
  #80
sparky's Avatar
Yes, Roque. What injectors are you running?
Old Oct 28, 2009 | 11:39 PM
  #81
xRoguex's Avatar
Stock so far. At 24psi.
255lph pump tho.
Old Oct 29, 2009 | 12:51 AM
  #82
sparky's Avatar
Do you have an AFR gauge? Even at 24 PSI, you are most likely on the ragged edge of lean, buddy. You need larger injectors.
Old Oct 29, 2009 | 04:41 AM
  #83
RyuEvoIX's Avatar
Dan (drb)
No matter the conditions there should only be about a 2-3mph variance at the track. Regardless of this trap speeds still tell far more about the power someone is making then a simple dyno number.
Old Oct 29, 2009 | 06:23 AM
  #84
JeffMas1587's Avatar
Originally Posted by BLKCarbonEVO
That looks no good! Please explain.
stock block, i either had a seized rod bearing which snapped the rod or the rod itself was the weak point and snapped. either way the rod snapped and went threw the front and back of the motor, also thew the oil pan
Old Oct 29, 2009 | 06:25 AM
  #85
batty200's Avatar
I definately think uncorrected dynojet numbers are more consistent than track e/t's. The main reason is weight. A dynojet needs not to know anything but the engine rpm and it can give you power and trq readings and without rpm it can still show power. No variables and very consistent. The rack is a good indicator and WAY better than a mustang dyno.
3. tire size
4. gearing
7. alignment
8 elevation
9. drag/downforce
10. shift points
11. shifting speed lift shifting vs no lift shifting.
Old Oct 29, 2009 | 08:39 AM
  #86
BLKCarbonEVO's Avatar
That sucks dude...
I agree but everyone is so use to a mustang dyno and they can't rely on a mustang to read the same so they have to see track e/t's. Only if everyone used the same correction factor or had a dynojet TTP has a dynojet.
Old Oct 29, 2009 | 09:01 AM
  #87
TTP Engineering's Avatar
That sucks dude...
TTP has an advanced Mustang Dyno with weather station measuring humidity, temperature and barometric pressure so that when someone dyno's their car at 0% humidity and 34*F in Oak Harbor, WA there is a standard SAE J1349 correction factor that will standardize the numbers based on 0% humidity and 77*F, despite the clear advantage in having a 34*F dyno room and air intake temperature at the WA dynojet, the MD numbers even when weather corrected are still at a huge disadvantage as dynojets to not LOWER whp based on colder intake temps, in fact the colder it gets, the HIGHER the Dynojet numbers get.
Those in the northeast like that advantage.
Old Oct 29, 2009 | 10:17 AM
  #88
RyuEvoIX's Avatar
That sucks dude...
Your under a false assumption that all dynojets read the same. They do not. Two of the same exact model dynojets could read differently from eachother depending upon variances in production, variances in assembly, etc.... That is why people say trap speeds tell all. Until then your simply dyno bench racing.
Old Oct 29, 2009 | 10:20 AM
  #89
JohnBradley's Avatar
Which is why we leave our dyno set to STD correction/smoothing 5 which is the apparent industry standard.
Old Oct 29, 2009 | 10:21 AM
  #90
Not true. As long as they are set to the same correction and smoothing all numbers are repeatable. If there is a difference it is VERY small. We have dyno'd on ETS's DJ which is 20 miles from ours in the same day and saw absolutely no difference with correction at STD/Smoothing 5.
