Stock Valve Question. Please Help.
Old Oct 26, 2009 | 06:58 AM
Sievers's Avatar
Is there a difference between factory exhaust and intake valves? If so, how can one tell which are which? I have to put some in a bare head of mine and need to be sure that it is done correctly.
Sorry if this has a very obvious answer. The valves are at home and I have not had a chance to look at them.
Thanks in advance.
Ryan
Old Oct 26, 2009 | 07:15 AM
tkklemann's Avatar
Intake valves are larger than the exhaust valves.
Old Oct 26, 2009 | 09:56 AM
Sievers's Avatar
Ok thanks.
I figured as much because that is how it is on almost all vehicles.
Are there any different markings?
Old Oct 26, 2009 | 04:04 PM
KenMasters's Avatar
Exhaust valves are hollow and filled with Natrium.
Old Oct 26, 2009 | 04:09 PM
HeadGames's Avatar
well....it kinda doesn't even matter if you didn't know, because the seat is different sizes. It would be like putting a square peg in a round hole, it would be so obvious if it was wrong. Your safe!!lol
Put some oil on them or Lucas additive on the stem before you stick them in.
Old Oct 26, 2009 | 08:31 PM
JohnnyTSi's Avatar
Intake Valve head diameter should be about 34mm
Exhaust Valve head diameter should be about 30.5mm
John-
Old Oct 27, 2009 | 02:02 AM
94AWDcoupe's Avatar
guess you never took an engine apart and found the intakes mounted where exhaust should be and visa versa. I HAVE.
the intakes are marked 6T the exhaust are marked 6N, but yes intakes are bigger and should be installed in the bigger seats.
Old Oct 27, 2009 | 02:57 PM
Sievers's Avatar
^Seriously? And it ran? If so, I have no idea how.
Headgames, I do know that there is a pretty big difference in size between intake and exhaust. The reason I was asking about any of this is because I have two full sets of valves (both intake and exhaust). Both sets have the same markings on the valves but when you take a micrometer to them there is a fairly large difference in size. I guess I should of made that more clear.
Anyways, I figured everything out last night.
Old Oct 27, 2009 | 06:55 PM
HeadGames's Avatar
Holy crap no!lol And the guy was probably wondering why it wouldn't run...
My post was one of confidence, I thought you asked the question perfectly...People who are not afraid to ask questions usually get it right is what I have learned.
Did you use anything on the stem?Lube I mean..
Old Oct 27, 2009 | 07:04 PM
Tonba's Avatar
^ My engine builder isnt too keen on putting oversize valves into my head. He seems to think its over kill...
What do you lot think about 1mm OS valves? Worth the hassle or not?
Old Oct 27, 2009 | 08:27 PM
sparky's Avatar
Originally Posted by Tonba
^ My engine builder isnt too keen on putting oversize valves into my head. He seems to think its over kill...What do you lot think about 1mm OS valves? Worth the hassle or not?
If I am not mistaken, 9sec9's record setting Evo has a Buschur Racing ported head with stock-sized valves. You might want to PM 9sec9.
Old Oct 27, 2009 | 10:18 PM
HeadGames's Avatar
unless your making over 1000whp it's not worth it..listen to him
Old Oct 28, 2009 | 01:58 AM
Tonba's Avatar
^ Then whats the go with all these 'race heads' by cosworth, etc running oversize valves?
Old Oct 28, 2009 | 08:53 AM
HeadGames's Avatar
what sounds better... stock or oversize?
The marketing works, everyone thinks you need it. But bigger does not always mean better, or better for you. It's just big. And to be honest, some use it to gain the flow or peak number that sells heads. The head will flow more at .500 lift, which is the number people give you when you ask how much their head flows with the oversize. We concentrate on valve job technology to combat the need to go oversize. Constantly updating and learning on the flowbench about angles and widths. We have made about 1000+whp in almost every engine combo, Honda, Toyota, Mitsu, Nissan, etc...with stock size valves, so I can't imagine why a car making half of that would need more. We have even set world records with stock size valves!
It's a up hill battle to convince people that less is more...
RyanB@VelocitySource
Jul 24, 2007 06:32 PM
jojipoji
Jul 3, 2007 02:30 PM
gbmoto313
32
May 14, 2007 07:17 AM
ex-honda
27
Oct 29, 2003 07:45 AM
