My FP Black
Old Apr 27, 2010 | 04:19 PM
  #136
BLKCarbonEVO's Avatar
Just cut your LICP and weld a bead around it. Had to do the same thing on my race pipe.
Mikey
Old Apr 27, 2010 | 04:22 PM
  #137
wizzo 8's Avatar
If you have the time just do it right and get the correct outlet pipe. I was tempted on cutting the race pipe also but then I wouldnt have the boost nipple for my synapse bov c-port.
Old Apr 27, 2010 | 04:24 PM
  #138
binky's Avatar
Mikey
Yeah? I think your right. It will be a lot easier to cut the LICP than the compressor outlet pipe.
Or do you think I should get a stock IX compressor outlet pipe?
So your saying to get the stock IX compressor pipe then?
-Bink
Old Apr 27, 2010 | 04:31 PM
  #139
[quote=binky;8247806]Yeah? I think your right. It will be a lot easier to cut the LICP than the compressor outlet pipe.
Correct. Just cut the LICP to the correct length. Don't need to do anything to the race pipe.
I would keep the race pipe. It is larger than the IX J pipe
Mikey
Old Apr 27, 2010 | 04:35 PM
  #140
binky's Avatar
Mikey
Alright, I think you convinced me
-Bink
Old Apr 27, 2010 | 04:37 PM
  #141
wizzo 8's Avatar
Good advice Mikey. I might even do that
  #142
binky's Avatar
Good advice. I might even do that
Yeah, it seems like the way to go.
-Bink
Old Apr 27, 2010 | 04:45 PM
  #143
Totally the way to go! No problem guys
Mikey
Old Apr 27, 2010 | 04:56 PM
  #144
binky's Avatar
Mikey
Thanks man!!
-Bink
Old May 4, 2010 | 05:06 PM
  #145
binky's Avatar
Ok -
I cut the intercooler pipe after getting a good measurement. I will post the measurements once I have a chance to go back out to the garage and add them to the first post - so people won't have to do what I did.
I spoke with my mechanic and he said he will put a roll bead in the pipe for free
I am also am in the process of painting my valve cover - so far so good. I glass beaded it yesterday and primed it today.
I drilled a hole and welded in a SS bung into my downpipe for my wideband.
I took off my Megan exhaust manifold and it was cracked in about 15 different spots, so I ordered a ported and polished stock exhaust manifold from MAP.
Slowly but surely I'm getting there. I am making a list of everything I've learned and everything I had to go through to get this build done so people get an idea of how much work it takes to do this job done right
-Bink
Old May 4, 2010 | 05:08 PM
  #146
wizzo 8's Avatar
Are you having the bolt holes for the shield shaved off the manifold also?
Old May 4, 2010 | 05:10 PM
  #147
binky's Avatar
Hey man, I didn't know that was an option? Is that a just for looks mod?
-Bink
Old May 4, 2010 | 05:20 PM
  #148
wizzo 8's Avatar
-Bink
Yea when mine cracks thats what I'm going to do. I think it looks better. If you are going to use the heat shield then leave them alone. I think you might have to do it yourself though.
Old May 4, 2010 | 05:22 PM
  #149
binky's Avatar
Ah, so your using a Megan exhaust manifold as well?
Yeah - If I was going to do it, I would have to do it myself, as I already ordered it from MAP.
-Bink
Old May 4, 2010 | 06:11 PM
  #150
CO_VR4's Avatar
Ok -
-Bink
Glass beading is a great way to get abrasive into your motor, and it's almost impossible to get out of a valve cover...
