My FP Black
Old Jul 24, 2011 | 07:14 AM
  #361
wizzo 8's Avatar
Looking good. I never thought of painting my subframe. Nice oil pan also. I have never seen pictures of it installed out of the car.
Old Jul 24, 2011 | 08:24 AM
  #362
binky's Avatar
Originally Posted by Mellon Racing
coming along nicely!
Thanks Chris Been bustin' my butt on this project...
Originally Posted by RockmanX
nice to know things coming on the up and up
Thanks Rock Enjoying your ride now that you picked it up?
Thanks man. How's you new 2.0?
I only painted it because I installed a new front sway bar. I figured while the engine was out I might as well as upgrade the front sway bar and coat the sub-frame. I used Rustoleum and then 3M rubberized undercoat spray to coat it.
I still have to finish the oil cooler / oil line to turbo / Buschur double pumper install / attach the downpipe / install the intake and I should be ready to fire it
-Bink
Old Jul 24, 2011 | 08:37 AM
  #363
wizzo 8's Avatar
Well take your time. No need to rush. You are getting closer and are probably getting excited. My new engine is running great so far. No oil burning off or leaks. I still have about 700-1000 miles of break in I still need to do. Ill be doing a compression test once its broken in to check engine health. Then tuning starts
Old Jul 24, 2011 | 11:26 PM
  #364
kaylabaldwin's Avatar
congrats, please update the performs.. im thinking ordering to. .
Old Aug 1, 2011 | 07:06 AM
  #365
binky's Avatar
The Evo Lives....
After many hours it's finally done.
I put 53.4 miles on it running Brad Penn SAE 30 'The Green Oil' for the initial break-in.
The break-in was done by accelerating in different gears and letting the motor slow the car down in order to seat the rings properly.
She didn't like to idle. With the said....the GSC S3's are awesome. They sound really mean. I adjusted the BISS screw per Lucas's advice and used Evoscan to activate the solenoid and it finally idled
I then drained the oil and switched to AMSOIL ARO 20W-50. And drove another 30 miles. The car has ~80 miles on it. Right around 70 miles it really started to drive nice and runs and idles like a champ.
Here's a teaser:
I'll upload a video in the next day or so
-Bink
Old Aug 1, 2011 | 08:31 PM
  #366
wizzo 8's Avatar
Nice! Good to hear you got it running and running good. Make sure to check your oil level regularly. Break in miles are not fun. I only have about 400 more to go though. How many break in miles are you going for?
Old Aug 2, 2011 | 05:34 AM
  #367
binky's Avatar
Thanks man!
No kidding.... break-in miles are a big PITA! Besides having to constantly vary the RPM....I'm nervous about driving it (just because I'm paranoid something might go wrong).
I plan on doing 1050 miles total. Then change the oil again and head over to the Dyno
-Bink
Old Aug 2, 2011 | 05:40 AM
  #368
wizzo 8's Avatar
I know what you mean. After about 500 miles or so you should get comfortable with the new motor and wont be worried as much. I was originally going for 2k miles but now I'm only going for 1500.
Old Aug 2, 2011 | 05:48 AM
  #369
binky's Avatar
Word
How are you breaking your engine in? Did you break your engine in similar to how I did? With a break-in oil for the first 50 miles then using the oil you will use normally after that? Or did you do it differently?
-Bink
Old Aug 2, 2011 | 03:49 PM
  #370
wizzo 8's Avatar
I asked AMS and Strictly modified about break in oil and the both said its not necessary but will speed up the break in. They said to just use the cheapest conventional oil I could find. I went with Auto zone 10-40 oil and followed AMSs break in guide shown here http://amsperformance.com/instructio...structions.pdf
Only difference is I'm only doing 1500 miles total. After that I will check my compression and do a leak done test. I will decide from there if I will go the extra 500 miles or not.
Old Aug 2, 2011 | 06:54 PM
  #371
guru_method's Avatar
Great looking bay!
Old Aug 3, 2011 | 09:11 AM
  #372
binky's Avatar
Cool. It's funny how different some engine break-in techniques are.
Originally Posted by guru_method
Great looking bay!
Thanks!
-Bink
Old Aug 3, 2011 | 06:43 PM
  #373
Mikey@Spec-Ops's Avatar
Looks amazing Binky. Can't wait to see you get that thing on a Dyno. My car will be going back on the dyno next week and 45psi. Should be interested. Let me know if you ever need anything brother.
Mikey
Old Aug 3, 2011 | 07:42 PM
  #374
forc3 f3d's Avatar
Write up on cleaning the engine bay!! That looks amazing!
Old Aug 5, 2011 | 07:50 AM
  #375
binky's Avatar
Mikey
Thanks Mikey, appreciate the kind words 45 PSI? Your nuts !
Thanks! I will write something up soon
-Bink
