Cosworth M2 IX lobe centerline?
Old Oct 30, 2009 | 06:48 PM
xceler8rob's Avatar
Why does it seem like I have all the problems doing things!
Anyone have the Lobe Centerline information for the Cosworth M2 for an evo 9?
I'm trying to degree my cams right now and cannot find it anywhere.
My cams are at 132 deg intatake, 111deg exh right now and I know the intake # is off. This is at all timing marks dead on!
Kelfords advertise at 107 int and 113 exh, so I'm assuming the Cosworth are similar.
Thanks
Old Oct 30, 2009 | 07:38 PM
xceler8rob's Avatar
I just refif the intake twice and got the exact same 113deg both times. I'm going to adjust both so that they are as close to the kelford 107I/113E. Sucks cause you gotta pull the belt for the 9 being since the mivec gear isnt adjustable!
Old Oct 31, 2009 | 12:26 PM
u189961's Avatar
Im looking at the spec sheet for my cosworth m2s and show the following:
intake: 131
exhaust: 114
hope this helps
I took a pic for you and uploaded:
Old Oct 31, 2009 | 10:23 PM
xceler8rob's Avatar
You the man! Everywehre looking and checking and I couldn't find it! They don't advertise that in anything.
Thanks again big help!
Old Nov 1, 2009 | 12:24 AM
u189961's Avatar
no problem, glad I could help.
Old Nov 1, 2009 | 02:13 AM
Ted B's Avatar
Your assumption is correct ... so long as we are talking about an EVO 8.
An EVO 9 has MIVEC. All EVO 9 intake cams are statically in the fully retarded position. This is why the 132 deg ATDC figure seems strange. Since MIVEC advances the cam (as soon as you start the engine), you'll never see that 132 figure with the engine running. What you see with the engine running all depends upon what's programmed in your MIVEC map.
Old Nov 1, 2009 | 08:13 PM
xceler8rob's Avatar
I am talking mivec. I will be pulling it apart again here tonight and re aligning to get 131 int 114 exh. I'm surprised I didnt hit a valve with teh intake at least 20 deg off. No weird noises or piston knock. Thanks for the help.
Old Nov 1, 2009 | 08:30 PM
MRfabolous's Avatar
what will degreing the cams do guys just wondering because mine are at on time with the stock timing marks thanks.
Old Nov 1, 2009 | 09:33 PM
Evo_Jay's Avatar
20 degress off?
You said you had it at:
in-132
ex-111
Spec is:
in-131
ex-114
Wheres the 20 degree difference?
Old Nov 2, 2009 | 07:15 PM
xceler8rob's Avatar
I thought I posted down that I rechecked it after that post and my intake cam was at 111!
degreeing your cams is important because not all cam manufacturers design cams based on factory specs. therefore when u set them at factory timing marks, they may not hit max lift ie the lobe centerline when they are needed to in the combustion cycle. the lobe centerline essentiallyty tells you at what point in the cranks rotation they are supposed to hit max lift which in term is suppose to give u the best performance as per their design by the manufacture. however, often times people have found that you can advance or retard by small amounts to achieve different characteristics such as more low ed torque or top end pull. from what I've read some guys have retarded their exhaust cam by two degrees for best performance with these cams.
I've also talked to people who have dropped them straight in without degreeing them and no problems. cosworth did recommend degreeing them to someone I had talk to them for me.
lets just say my car runs like crap with them aligned at factory timing marks!
thanks
Old Nov 2, 2009 | 09:48 PM
Evo_Jay's Avatar
Oh okay.
lbcevo
Oct 7, 2015 11:57 PM
David Buschur
18
Mar 17, 2012 10:32 PM
kaj
18
May 7, 2010 08:45 PM
JC evo1
54
Oct 12, 2009 07:59 PM
SmokinJoe
22
May 27, 2004 09:37 AM
