slipping
Old Nov 6, 2009 | 08:33 PM
gozita's Avatar
slipping
I have a 2003 mitsubishi evo 8. It has a stage 3 exedy clutch kit installed. My problem. The car has only 10k on it. I bought the car from my friend and the car has been sitting in his garage for 2 years without moving or starting. I got the car about 2 weeks ago. Everytime I step on the clutch, it makes a grinding noise. Also, when i'm driving it, I punch the gas, the car will do a quick pick but then the rpm goes up but the car don't doesn't do anything. Do you think my clutch is getting bad? What's causing the grinding noise? HELP!!!
Old Nov 6, 2009 | 08:36 PM
buchnerj's Avatar
If it is indeed an Exedy triple, welcome to the world of multiplate clutches, and they make noise, triples especially. A LOT sometimes with the pedal pushed in at idle and in between shifts. In regards to the slipping, if you put the car in a higher gear and hit the gas, does it slip or hold strong? If it slips, the clutch is on the way out, if not, could be another drivetrain issue.
Old Nov 6, 2009 | 09:11 PM
charon2123's Avatar
Sitting for two years without starting is not good for the car, I would be careful and check to see if any seals had dry rotted from lack of lubrication.
Old Nov 6, 2009 | 09:29 PM
Ev0ikon's Avatar
10K and slipping the aftermarket stage 3 clutch is Unlikely. But what you said does mean the clutch is slipping.
Old Nov 6, 2009 | 10:17 PM
gozita's Avatar
I've check everything, the engine is fully built, it's doing about 600+hp at 30psi. Right now, it's only set at 22psi. also, when I punch the gas, it started to choke at about 7000rpm.
Old Nov 6, 2009 | 10:20 PM
buchnerj's Avatar
Choke? The point is to have the clutch engaged and be in a higher gear than normal and hit the gas to see if the clutch slips. That was the point of doing that. So your saying the engine has trouble revving over 7k? Thats a different problem (probably) entirely. I thought you said the clutch slipped regardless of any power increasing, if that is so how are you even getting it up that high in the RPM band? I would say that this car sitting around has had serious repercussions on its reliability. Did you do a compression test?
Shanedixon1987
12
Jan 7, 2016 10:04 AM
kanovic
Jan 28, 2012 02:15 PM
Huntington MR06
Oct 8, 2009 03:11 PM
RicerX1
Mitsubishi TC-SST Discussion
13
Jul 6, 2009 12:53 AM
J8dailo
Apr 17, 2009 07:57 PM
