evo can sit all day and not overheat
Old Oct 22, 2003 | 07:28 PM
mazdryk's Avatar
Just to let you all know today my evo sat for 3 hours running with the a/c on in 90 degree florida weather. The temp gauge never budged. How did this happen you ask? I was dropping my 3 year old off at the babysitters when he decided to run back to my car and lock the doors and jump out. So im sittng there like a jack assssss locked out of my car. I then went to my house to try and find my lost extra set of keys. I tore apart my house cause i was pissed it now looks like my house was robbed. The keys are still lost. I called a lock smith and he said 30-45 minutes. 45 minutes later i call and he cancels so i call another lock smith. He finally gets there and i check the time. 3 hours had passed. I was prepared to break my car window if i saw even a hint of that temp gauge moving. Is there anything i should be worried about some co-workers said my catalytic converter?
Old Oct 22, 2003 | 07:32 PM
VegasEvoOwner's Avatar
My car has sat in 115 degree weather with A/C on for about 45 mins... no problem. Summer was too hot.
Old Oct 22, 2003 | 07:37 PM
SinCityEvo's Avatar
Can't you foul the plugs by letting it idle so long?
Old Oct 23, 2003 | 12:24 AM
909's Avatar
909
umm... Japanese cars never overheat..at least the new age ones. I cant say the same for american and european cars.
Old Oct 23, 2003 | 12:40 AM
SAEVO's Avatar
Thats some crazy crap. Glad to hear nothing was hurt on the car.
Old Oct 23, 2003 | 12:53 AM
1QWKEVO's Avatar
the plugs can load up on it, as too the cat from running so rich. Take the car out for some nice strong boosting runs and let the ignition burn off the excess carbon. If needed pull the plugs and check them, shouldn't be any worries at all.
Old Oct 23, 2003 | 12:55 AM
Alias's Avatar
Dude, why didn't you just call the Mitsu roadside service? Doesn't the service include Locked Out? I know it includes gas, changing flat tires, etc but I think it also includes Locked Out too. Correct me if I am wrong.
Old Oct 23, 2003 | 08:57 AM
stevEVO8's Avatar
Dude that would suck, Glad to hear you didnt kill the little one for that.....I know some people would have gone ape ****.
Old Oct 23, 2003 | 10:18 AM
AvatarOfWar's Avatar
The asians have figured out a way to eliminate thermostats that fail? What exactly is the cut-off date for "new age" vs "old age" Japanese vehicles?
j/k
Old Oct 23, 2003 | 10:25 AM
DoingAnything's Avatar
As long as your fans are working you won't overheat your car. My racecar starts overheating if it sits on the grid for too long (no fan, too much weight ), the second the car starts moving forward and air gets pushed through the radiator then i'm all good.
Old Oct 23, 2003 | 10:47 AM
I just do not see how this can be true - if that's the case, what's the point of the radiator at all? Some engines are air-cooled (original VW beetles, Katana motorcycles), but they're designed with air-flow paths for this very purpose. Our heads and engine block are designed to be liquid cooled.
When I was travelling on the highway at 75mph in my Ford Explorer, the thermostat stuck closed and it overheated fast. The fan was operational, and I had a lot of wind across the engine. Are you telling me it's because Ford doesn't have ancient JDM secrets built into their air-flow design?
Old Oct 23, 2003 | 11:06 AM
mazdryk's Avatar
I think that he means as long as you have a fan and your thermostat doesnt get stuck closed.
Old Oct 23, 2003 | 11:09 AM
Bluto's Avatar
http://auto.howstuffworks.com/cooling-system.htm
Fans provide airflow while car is stationary.
A thermostat stuck closed will not allow the transfer of coolant in engine. Does not matter how fast you drive.
Mackman
Feb 17, 2017 05:27 PM
Viral Racing
Jan 25, 2015 09:55 AM
Evo_Jr
North Texas Evo Club (NTEC)
11
Apr 12, 2012 09:26 AM
bxthai
May 26, 2009 03:37 AM
Parikh1234
Nov 8, 2008 01:17 PM
