Clutch is shot right?
Old Nov 10, 2009 | 09:00 PM
Unrivaled's Avatar
So car on a flat surface complete stop, put in gear and release the clutch and car doesn't die but limps a little and starts to move forward. And this will happen in every gear and will only die if I put foot on brake (obviously). I usually don't drive it during the week because I take the bus to school but, I'm going back home for thanksgiving break about 400 mile drive.. will she live through it?!
Old Nov 10, 2009 | 09:02 PM
06ravenmr's Avatar
i dont understand what its doing..
Old Nov 10, 2009 | 09:04 PM
Unrivaled's Avatar
Basically it won't die in any gear from a complete stop with the no foot on the clutch.. Does that clarify it?
josel_atr's Avatar
try this: drive on 5th gear, but keep the rpm low (say around 2k), then floor the gas. if the rpm shoots up without gaining speed, this means your clutch is slipping.
if this happens, welcome to the club. time for a new clutch. dont drive it far without getting it checked out first.
Old Nov 10, 2009 | 09:05 PM
Q8_EVO's Avatar
.. u'll be fine
Old Nov 10, 2009 | 09:06 PM
benniboi08's Avatar
either your clutch is on its way out or engagement point (pedal) adjustment needs to be done. By the sound of it, clutch is going. I highly dont recommend driving 400 miles home with the evo. *have AAA on speed dial if you decide to go for it*
Old Nov 10, 2009 | 09:07 PM
Unrivaled's Avatar
Driving with no boost should help right?
Old Nov 10, 2009 | 09:08 PM
benniboi08's Avatar
I used to use that old trick to test if my clutch is good but heard else where you are flooding the injectors and for turbo cars it can cause damage. someone correct me or let me know if this does any thing bad to the car.
Old Nov 10, 2009 | 09:09 PM
benniboi08's Avatar
sure, after all we do drive lancers, with an upgraded evolution badge.
Old Nov 10, 2009 | 11:16 PM
Kracka's Avatar
Are you dumping the clutch or releasing it slowly? If you're releasing it slowly then it sounds fine to me. If you're dumping it then you have an issue.
Old Nov 11, 2009 | 01:52 AM
Unrivaled's Avatar
I'm releasing it slowly but there's really like no "catch point" and I put no gas in while releasing the clutch either. Thanks for all the inuputs
Old Nov 11, 2009 | 12:01 PM
barneyb's Avatar
Pure, unadulterated, 100% BS. Explain how you flood an injector that is alway full of gas.
The test is the correct one for checking the clutch.
Old Nov 11, 2009 | 12:04 PM
benniboi08's Avatar
^ thank you barney. Now i can let my friend know he is wrong. We had the longest argument about this and he was giving me "its cuz we have turbo car excuse"
TurboTylerIX
21
Dec 19, 2017 11:16 AM
slippi84
17
Nov 27, 2015 06:37 PM
Btaylor36
Lancer Tranny/Drivetrain Tech
Aug 27, 2015 06:03 PM
Pegasus
Oct 4, 2014 10:18 PM
MTRJunior
Jan 20, 2009 04:29 PM
