"regular" ARP headstuds vs. ARP L19 headstuds
Old Nov 26, 2009 | 11:22 AM
  #31
nos51's Avatar
Originally Posted by 190hpkilla
factory torque spec works like charm on my L19s.
what kind of boost power you making?
Old Nov 26, 2009 | 11:30 AM
  #32
D-VO's Avatar
Originally Posted by MR Turco
There is a lot of conflicting information and opinions on the regular ARP headstuds. Some say they are good for 700whp some say they are no better than the stock bolts. Do some reading and make your own determination.
WOW! I can't believe anyone would say the ARP's are no better than stock. I lifted my head (bent the stockers) while only spiking 26psi!
Old Nov 26, 2009 | 03:17 PM
  #33
aschold's Avatar
i dont know about you guys but when I was building my engine the difference in $120 and $220 is not enough to go cheap!!!!
Why would you cheap out over 100 bucks???
Ive had/seen regular studs give under high boost under 700hp.
Well, because as someone else brought up, while these may be the best choice for high horsepower, for lower horsepower set-ups where you can get away with it, these would be better. Let's say you get a bad tank of gas or make a tuning mistake. Would you rather lift the head and have to change the headgasket, or would you rather throw a rod or spin a bearing? Something's gotta give, for me, I'd rather it just be the head. Thats why after careful thought, I made my decision and ordered the standard ARPs.
Old Nov 26, 2009 | 07:32 PM
  #34
E85evo8's Avatar
does anyone know if ARP recommends using oil or arp "lube" when installing the L19's?
Old Nov 26, 2009 | 07:51 PM
  #35
ryno529's Avatar
moly lube.
Old Nov 26, 2009 | 07:52 PM
  #36
fre's Avatar
fre
The lube that comes with them is recommended. Oil can be used, but it is not preferable.
Old Nov 26, 2009 | 08:38 PM
  #37
ryno529's Avatar
moly lube is what ARP supplies. If you use oil the torque spec changes. I am not 100% but i believe they get torqued higher with oil. I would stick with the moly lube .
Old Nov 26, 2009 | 09:44 PM
  #38
Shea561's Avatar
If you can chase the holes to clear debris before putting the new studs in. A grain of sand or metal shaving can make or break ya. Something commonly looked over when installing, studs, bolts, etc... just thought I'd throw that out there in the mix.
Old Nov 27, 2009 | 06:57 AM
  #39
E85evo8's Avatar
I'm no stranger to headstuds and will p/u some arp "moly lube"...95ft/lbs is what i'll be torquing them down to. I've used motor oil in the past and ARP does give a tq. if using motor oil and it is higher than if using their "lube"
Old Nov 28, 2009 | 02:58 PM
  #40
CO_VR4's Avatar
BTW: ExtremePSI has the ARP L19 head stud set for the Evo on sale for Black Friday for $179...
Old Nov 28, 2009 | 03:17 PM
  #41
Shea561's Avatar
^^^ Killer deal
Chris Smith
Apr 3, 2017 06:13 PM
opie
Aug 10, 2016 09:52 AM
asu11
Jul 5, 2015 03:57 AM
fortyPSIrs
55
Apr 16, 2014 10:02 AM
slowsrt4:(
Sep 28, 2013 05:29 AM
