Comp surging again
Old Nov 12, 2009 | 03:03 AM
ItalianEvo's Avatar
Comp surging again
Hi All,
I'm getting again what I think it's compressor surging with my GT3071 anti-surge ported.
Accelerating WOT from 3200 to 4000 in 4th and 5th gear, I get the annoying wosh wosh wosh noise, and the car stumbles a bit, so definitely is surging.
As i read, this kind of compressor surging (WOT from low rpm, longer gears, during spool up to max pressure 1.80 bar) can be caused by a too retarded ignition timing in the spool up region, that causes a too fast pressure rise:
is this correct ?
This is my ignition map, any advice is really appreciated.
For example, is it correct that from 3000 to 4000 I have less advance that over 4000?
Thank you.
Old Nov 12, 2009 | 03:49 AM
Evo_Jay's Avatar
what type of engine management are you running?
Old Nov 12, 2009 | 10:56 AM
ItalianEvo's Avatar
Hi, Motec M400
Does it make a difference ?
Old Nov 12, 2009 | 12:09 PM
Evo_Jay's Avatar
Originally Posted by ItalianEvo
Hi, Motec M400
Nope, was just asking.
Old Nov 12, 2009 | 12:32 PM
JC evo1's Avatar
Hi All,
is this correct ?
ive been having a problem with the static ignition timing retarding and it definatley makes comp surge worse. Im running a 3582 with out a ported front cover. Have a look at the dyno sheet, the only difference between these two runs are the static timing retarded alot, something like 6 or 8 degrees, it spooled the turbo a bit faster but lost a lot of power and comp surge is worse.
Old Nov 14, 2009 | 09:34 AM
ItalianEvo's Avatar
Very interesting, thanks
youra6
Dec 21, 2016 12:54 PM
awdordie
14
Nov 28, 2011 08:11 PM
Tractionlimit
Evo X Dyno Results
21
Mar 20, 2009 09:34 PM
JDMevoBOOST
71
Jul 25, 2008 04:54 PM
blackdemon
26
Jan 20, 2008 01:44 AM
