Before I pull it apart, is there anything missing?
Current mods:
-GSC S1 Cams
-ETS 3inch IC
-Amsoil Cone Filter
-MBC
-Ported o2 housing and exhaust Manifold
-3in turbo back
-UICP and LICP
Mods to go on:
-FP Red +Oil Line
-HFS-6 Aquamist Kit
-880cc FIC injectors
-65mm throttle body (have gasket)
-Ported Intake Manifold
-Wideband o2 sensor (still have to weld in bung)
Things i still need:
-Tank for Meth
-Intake manifold gasket
-Turbo manifold gasket
Is there anything I'm missing? The car cannot be off the road for super long so i want to have everything ready for it...
I know the GSC S1's aren't great for this setup but o well, I don't have enough $$ left
(especially considering I'm probably going to leave my 6speed on the high way soon after the car leaves the dyno)
Thanks
(p.s. how do high flow cats react to meth?)
-GSC S1 Cams
-ETS 3inch IC
-Amsoil Cone Filter
-MBC
-3in turbo back
-UICP and LICP
Mods to go on:
-FP Red +Oil Line
-HFS-6 Aquamist Kit
-Tank for Meth
(especially considering I'm probably going to leave my 6speed on the high way soon after the car leaves the dyno)Thanks
man i think the S1 cams are pretty awesome on the red.. did you see this thread? https://www.evolutionm.net/forums/no...ml#post7723821
The 6 speed is a trooper man!!!!!! have the FAITH. I have had both BTW and the 6 speed took miles upon miles of abuse, including NUMEROUS drag passes at varying power levels up to 520.
AND the 520hp passes were all NO lifting too!!
If you got the 80mm cover version of the Red pick up FP's silicone intake pipe, otherwise, go for Samco's silicone intake pipe. For the IM gasket pick up a heat-barrier phenolic spacer gasket.
Although it's the only set of aftermarket cams I've owned in the evo, the S1's have been simply great!
That's really promising!
Hollywood_Evo
16
Mar 11, 2012 05:33 PM
Go_Lancer_Go
19
Sep 29, 2010 08:38 AM
GgreyEVOIX
28
Dec 30, 2006 02:43 PM
