Super Stiff Shifting
Old Nov 23, 2009 | 08:43 PM
huevosrancheros's Avatar
Originally Posted by Don Q
Hi guys,
I just installed a short shifter, shifter and underhood bushings and now the shifter is MEGA stiff. I mean, I don't know if it normal or not... If I put it in neutral and try to wiggle it left and right its so stiff that if I push it to the right the shifter stays there instead of returning back to neutral...
Is the short shifter supposed to be like this??? I just want to know since this is the first short shifter I have installed/driven.
try pulling off the underhood bushings and slather those bad boys up with anti-seize. Make those c-clips you slide onto those bushings clear the linkage. Those c-clips should rotate freely.
Old Nov 23, 2009 | 08:51 PM
EvoRob22's Avatar
...... Already solved. 29$ shipped is a steal even with some fabrication needed to be done. Congrats on fixing the problem again .
Old Nov 24, 2009 | 09:11 AM
xpehbam's Avatar
Thanks for the info. Very helpful!!!!
Old Dec 7, 2009 | 05:58 AM
xpehbam's Avatar
What helped me is lube on the shifter cables!!!
Old Dec 7, 2009 | 06:21 AM
detroit pistins's Avatar
Hi guys,
Great to see the issue was solved already, but from what ur saying up above, it seems like u have put back the spring arms wrong, it happened to me when I installed my B&M where I placed the arms in a X pattern.
Old Dec 7, 2009 | 06:56 AM
here is a quick pic for those wanna see a comparison (stock vs b&m)
bbyevo8u
17
Apr 7, 2016 01:37 PM
eazysnatch
Apr 16, 2015 09:15 AM
sixela03
May 24, 2011 12:31 PM
corymacd
Sep 26, 2009 08:43 PM
ancker
Apr 2, 2008 06:33 PM
