Amsoil Users...
Old Apr 26, 2011 | 07:02 PM
  #31
Paintballguy's Avatar
I just switched over to Amsoil Super Synthetic 0w30. Loving it so far. I think I am going to run it in my Tacoma also on the next oil change.
Old Apr 27, 2011 | 11:04 AM
  #32
boostnMA's Avatar
The following information is stated on the amsoil website:
http://www.amsoil.com/mygarage/Produ...BISHI+LANCER+H
2005 MITSUBISHI LANCER 2.0L 4-cyl Engine Code [D] 4G63 Turbo
Engine Oil
Grade 1......SL[1]Maximum Performance Signature Series 100% Synthetic 0W-30 Motor Oil (AZOQT) Signature Series 100% Synthetic 0W-30 Motor Oil (AZOQT)
Drain Interval Information
Maximum Performance SAE 10W-30 Synthetic Motor Oil (ATMQT) SAE 10W-30 Synthetic Motor Oil (ATMQT)
Performance Plus XL 10W-30 Synthetic Motor Oil (XLTQT) XL 10W-30 Synthetic Motor Oil (XLTQT)
Performance Synthetic 10W30 OE Motor Oil (OETQT) Synthetic 10W30 OE Motor Oil (OETQT)
All TEMPS......10W-30
Manual Transmission,W6MAA (6-SPD)......GL-4
No AMSOIL Product Recommendation
Manual Transmission,W5M51 (5-SPD)......GL-4
Synthetic Manual Transmission and Transaxle Gear Lube (75W-90) API GL-4 (MTGQT)
Limited Slip Differential, Rear......GLS [2]
All TEMPS......
Transfer Case,......GL-5
SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT)
75W-90 Synthetic Long Life Gear Lube (FGRQT)
SEVERE GEAR 75W-110 Synthetic EP Lubricant (SVTQT)
Fluids
Power Steering Fluid......PS
Power Steering Fluid (PSFCN)
Brake Fluid......HB
AMSOIL Brake Fluid DOT-3 (BF3SN)
Clutch Fluid......HB
[1] Must use synthetic engine oil.
[2] Mitsubishi Diamond Queen LSD Gear Oil.
FILTERS: Oil FilterAbsolute Efficiency Oil Filter (Ea15k46)Oil FilterWIX 57092 Oil FilterAir FilterINJEN-AMSOIL Air Intake System (SP1898P)[1]Air FilterWIX 46215 Air Filter
[1] Chrome Finish; Short Ram Kit - Evo VIII, MR, IX Cast Aluminum Intake System With Full Intercooler Piping
NGK PLUGS AND WIRESETS: PREMIUMIRIDIUMPLUGIGR7A-G ^ #WIRESETWIRESETRC-MX107[1]
[1] 2 Lead Slave Set
WIPER BLADES: Blade ClassDriverPassengerExactFitT241 T181 NeoFormT16240 T16180 WinterT37245 T37180
CHASSIS LUBRICATION: 0 Fittings, 0 Plugs
CAPACITIES: Engine, with filter..........5.4 quarts [1]
Cooling System, Initial Fill..........6.6 quarts
AMSOIL Antifreeze and Engine Coolant
Manual Transmission, W5M51 (5-SPD)..........6 pints
Manual Transmission, W6MAA (6-SPD)..........4.7 pints
Differential, Rear..........1.3 pints
Transfer Case, ..........1.3 pints
[1] Capacity includes oil cooler.
TORQUES: Oil Drain Plug.....26-32 ft/lbs
Manual Transmission
Fill Plug 22-25 ft/lbs
Drain Plug 22-25 ft/lbs
Old Apr 27, 2011 | 11:33 PM
  #33
nudge120's Avatar
Look like I need to find a new rear diff fluid. When did that change?
Old May 4, 2011 | 04:42 PM
  #34
Cory99GST's Avatar
I use Amsoil in everything. It's a great oil, and is very well proven. I'm not saying mobil 1 or others are good, but i love amsoil, from cars to snowmobiles to dirt bikes to boats to jet skis, it's in everything with a motor i own haha.
Old May 4, 2011 | 05:13 PM
  #35
Cory99GST's Avatar
If anyone in the Minnesota area needs a dealer hookup/price on oil, or lets say a cheaper place then napa to buy amsoil, let me know
golgo13
445
May 26, 2025 05:37 PM
TommiM
410
May 26, 2022 08:41 AM
MR. EVO MR
679
Dec 1, 2016 05:14 PM
apagan01
Oct 20, 2016 07:47 PM
Blitz
May 13, 2008 10:22 AM
