GSC S1 cam on Evo 7
Old Nov 24, 2009 | 03:55 PM
honfui's Avatar
GSC S1 cam on Evo 7
hi,
Do i need adjustable cam pully such as hks when installing S1 cam? My mech told me i need to get a set of adjustable cam pully as my car idle is like sh*t after the cam installed... or is there any thing missed out by him?
Old Nov 24, 2009 | 03:58 PM
Murf's Avatar
no cam gears are needed and if you get evo 8 cams you will have no problem putting them in a 7. same engine minus the antilag setup.
Old Nov 24, 2009 | 07:06 PM
honfui's Avatar
is there any setting on the stock cam gears?
Old Nov 25, 2009 | 04:36 PM
eTiLiKo's Avatar
You have only to remap your ECU
Old Dec 12, 2009 | 04:12 AM
honfui's Avatar
i bought a set of hks adjustable pulley instead of remap ecu as there's no tuner to help on remap the ecu. Wat setting I should set for the hks pulley?
Thanks.
Old Dec 12, 2009 | 07:09 AM
Kracka's Avatar
Just use your stock gears, an adjustable cam gear is not a replacement for a tune.
Old Dec 12, 2009 | 06:27 PM
honfui's Avatar
i was told i can either remap or use the adjustable pulley to "fix" this issue. I'm hoping to use the adjustable pulley to resolve the idling issue first so I can have my car back while i getting my standalone ecu early next year.
Old Dec 12, 2009 | 07:10 PM
honfui's Avatar
i'm planning to set the cam gears to -2 in/-1 ex. will that improve the idling?
Old Dec 12, 2009 | 07:25 PM
RSMike's Avatar
idle will improve if you decrease the overlap, but any means.
so advancing the exhaust, or retarding the intake.
tuning for power/response is another matter.
my kelfords 272 made the best response with +5/+3, but we lost top end (which i'm happy with)
Acuality
Jun 23, 2016 08:09 PM
AWD_Terror
24
Apr 8, 2011 07:48 PM
jameswwt
Sep 29, 2010 08:19 PM
dustyp34
Lancer Engine Tech
11
Dec 8, 2008 06:07 PM
paul North
16
Sep 3, 2007 04:49 AM
